Question about Drills
How to charge battery
Can't find connection to the charger
    Scholar:
  • 136 Answers
What charger? What tool?
Posted on Nov 29, 2014
I can leave it plugged in for 24 hours and not have a full charge. Is this the batteries or the on board charger
There are a few things to consider with this type of problem.
How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
Jun 15, 2015 | Pride New Mobility Victory XL 4 Wheel...
Is the charger to be "on" while charging it; then on while hooked to battery?
The portable charger should NOTE be connected to a battery while the battery is connected to a vehicle! Charge the battery off the car, then disconnect the charger and put the battery into the vehicle to start it! If the charger is not working check the fuse! If that is ok then probably damaged the circuitry!
Jan 02, 2015 | Cars & Trucks
12v battery charge doesn't work in car
A few reasons why the charger is not charging the battery: The charger itself is not working; The battery will not take a charge, the battery can be 'dead'. If you can, connect the charger to another battery, just to see if it is working. The charge indicator needle will move. If you have confirmed that the charger is working, then the battery may be beyond charging. Make sure the connections from the charger to the battery terminals are tight.
Jun 11, 2014 | Cars & Trucks
Mobility scooter battery serial connection charger question
if the charger is a 12-14 v charger you would have to charge 1 of the batteries at the time. connecting both in parallel during charging would cause a short. and in series (the way you have them wired) would provide too low a voltage for the batteries (6-7v each)
if the charger is 24-28v charger you would connect to the wires going from the batteries to the controls/motors (not the connection between the batteries) this will provide each of the batteries 12-14v charge
Mar 05, 2014 | Health & Beauty
Charging the battery
If you have a battery charger, remove the battery cover to expose the battery terminals then you can connect the battery charge to the battery.
Make sure you connect the positive lead from the charger to the positive terminal on the battery and the negative lead from the charger to the negative terminal on the battery before you power up the battery charger.
When you have finished charging the battery, power off the battery charger before you disconnect the leads from the battery.
Jul 03, 2012 | Hyosung Motorcycles
Jul 03, 2012 | 2009 Hyosung GT 250
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
