Question about Dryers
Is there a positive \negative wire on the heating element of the nexxtech soldering iron?
The barrel of the iron is to long is to long to use for cutting stencils. I need more of a pencil. Trying to write with pencil that has its lead 8in from your hand is terribly difficult and makes straight lines impossible. While trying to alter the iron I pulled out the heating element wires by accident. I know nothing about electronics.Is there a positive/negative wire on the heating element and the cord that plugs in the wall? I don'twant to reconnect it improperly and have it blow up or start a fire. On a side note can iI lower the heat a little ?
  • Lynne Sek
    Lynne Sek Nov 29, 2014
    i have no flipping idea how my question ended up in the dryer section. i never mentioned dryers any where. my question is about a soldering iron.
    Scholar:
  • 136 Answers
It won't make any difference when you hook it back up. And the only way you can adjust the heat is to adjust the amount of electrical power going in. It would be cheaper to buy an adjustable unit then to try to create one though
Posted on Nov 29, 2014
  • Lynne Sek
    Lynne Sek Nov 30, 2014
    Thank you Mike that was helpful. When I asked about lowering the heat, I wasn't expecting an electrical alteration. I was thinking maybe a metal ring or some kind or funky tip. I actually am thinking of soldering a nail to a screw so I have a 90 angle. If I used a longer nail would that absorb enough heat to lower the temp? Just a way yo divert the heat going to the tip. I'm on a serious budget so something I may have around the house. I really cannot afford to replace this iron.
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
aborcass
  • 2651 Answers
SOURCE: installing a new heating element on my Whirlpool dryer.
shouldnt make a diff, the orange wire can only go in one place,adn the 2 reds make no difference.. the only thing you need to do is remove the thermostat from the oldelemnt and install it on the new heater
Posted on Dec 04, 2008
  • 45 Answers
SOURCE: My kenmore series 80 electric dryer does not heat.
Yes, hook it up, but before you do that Vacuumn every piece of lint out of the cabinet. Also check TCO and check the thermostats for continuity. They should all read zero ohms.If one of them is open, replace it.
Also use your ohmmeter to check the heating element, It should not show an open condition.
Posted on Jul 29, 2009
VtToolMan
  • 704 Answers
SOURCE: white westinghouse wdg336red1
Just posting the link to the manual, since we've already discussed this previously on a peer-to-peer basis.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/95326237.pdf
Let me know if you hit any snags reattaching the wiring connection points, etc.
Hope you find this Very Helpful and best regards!
Posted on Nov 18, 2009
Testimonial: "Just fantastic Help Vt Tool the best tech."
  • 1218 Answers
SOURCE: Kenmore dryer, heat element ALWAYS on
Good day,
Sounds as if the element inside the canister has shorted to the canister body. You will have to remove the element to check it. I'll include a tutorial on how.
If that doesn't resolve the issue, please reply back.. Whirlpool makes Kenmore dryers.
Jack
http://www.applianceaid.com/wp_element.html
P.S. Look close. It doesn't take much....
Posted on Feb 01, 2010
How do I repair detached incase wiring
Heating element connections r riveted together - u can't solder them as it would melt when running.
If the wire detached at the element it is near impossible to reattach it.
U would have to remove the rivet and replace it with the wires connected. My experience is that the mica that it is attached to is too fragile to get the ribvet removed.
Oct 06, 2014 | Welding Tools
Iron ultraglide will not work
It is likely either a wire to the heating element or a loose solder joint or possibly loose capacitor that needs to be re soldered
Jun 05, 2012 | Irons
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
When i hook up my cobra 29 Ltd to my pickup it keeps blowing fuses, red to postive and black to negative..Cannot figure out whats wrong
You have hooked your power wire up backwards at some point and blown the polarity protection diodes.
This requires opening the radio and using a soldering iron to remove and replace the blown diode.
You will need:
  1. Soldering Iron
  2. Solder
  3. De-soldering braid
  4. N1004 diode or better.
  5. Phillips head screw driver.
Using the phillips head screw driver to take the bottom cover of the radio off being careful of the speaker wires. Using the soldering iron, heat the solder on the tabs of the speaker and pull off the wires. No need to use the de-soldering braid to remove the solder. You should do this to make it easier to handle the radio, and to avoid damage to the speaker or wires etc.
Now take the cover off the top of the radio. This will reveal the "Trace" side of the board. This is where all of the components are soldered to the board.
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D23. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D23 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Once you have located the points at which the diode is soldered too, do not de-solder it yet. Make note of which side of the diode the white band is on. This is important, putting the diode in with the wrong polarity will make the radio not work.
After you take note of the white band you may now use the de-soldering braid to remove the solder from the trace side of the board. To do this, place the braid over the solder point. put the tip of the soldering iron on the braid and press it down to the solder point. You will see it **** the solder into the braid.
Once the solder is off both solder point, flip the radio and remove the bad diode.
Put the new diode in, making sure the white band is on the same side as the original diode.
Once again flip the radio over to trace side of the board and solder the new diode in. To do this place the tip on the solder point, making sure to touch both the solder point of the board and the wire from the diode. take the solder and touch it to the solder point, not the soldering iron tip. Once enough solder is on the point you can remove the soldering tip. Don't use too much solder.
Once both points have been re-soldered, solder the speaker wires back to the speaker. Red is positive, it connects to the tab marked by the positive symbol "+". The white wire is negative. It goes to the negative symbol, "-". You can just reheat the tab, and put the end of the wire into the melted solder and remove the solder tip while holding the wire in place until it cools enough harden again.
After the speaker is re-soldered, Put the covers back on. Now be very careful hooking up the radio to power. If you hook it up backwards again it will blow the diode again. Once the power wire is connected, turn on the radio, it should work fine at this point.
Good Luck!
Oct 07, 2010 | Cobra 29 LTD CB Radio
How to disassemble weller soldering iron Magnastat Station - 42W
Hello, if the head element in the barrel of this soldering iron is shot. Recycle it and save the copper and other materials for recycling. Recyclers are pay $3.20/lb for copper, $1.86/lb for brass.
Remove the three screw on the front plate and pull the cord. It's apart. GB...stewbison
Aug 08, 2010 | Weller SP80 Soldering Iron
When the 100 watt iron heats up, it blows the circuit, even when it is the only appliance plugged in. House is 12 years old, so the wiring should be ok. What's wrong?
where the plug and cord wires are connected inside the barrel, the wires start to fray from rotating the iron barrel and start to fray and short,some irons you can remove the barrel from the handle by removing screws from the body of the iron,some are not able to be disassembled,if you can plug it in and the breaker doesnt blow,then rotate the cord and see if it blows the breaker then,this is a good sign of what is posted in my comment above
Mar 10, 2010 | Welding Tools
Iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    Soldering gun Question
    Where soldering irons have a heating element that heats a copper or alloy tip; in a soldering gun, the tip is also the heating element. Most soldering guns are hot enough to solder in less than 5 seconds and cool enough to touch in less than a minute. Soldering guns are ideal for the typical home electrical job like connecting speakers or installing automotive accessories. These jobs often have only a few connections to solder so a soldering gun can be a real time saver.
    Aug 27, 2008 | Milwaukee Tool Weller 300/200 Watts, 120v...
    Replacing The IC's
    Use a digital camera to take pictures of the chassis. Review the pictures to see if they can be used to reassemble the wiring plugs or restore the wire tie up positions. Remove the three screws that are located on the front edge of the chassis. After removing wires from their tie up positions or disconecting plugs the goal is to move the chassis into a position to expose the bottom side. Find a place to tie up the chassis using a piece of wire to one of the back screws to anchor this position. Use fresh solder wick and a 60Watt iron to remove the heat sink solder tabs switch to a 25 to 30 watt iron to remove the solder on the STK392-560 ic's. Remove the ic's from the heat sink and apply fresh heat sink grease before mounting the new ic's to the heat sink. Line the pins uniformly on the ic's if needed to install the ic/heat sink assembly. Use a flashlight or lamp to make it easier to see if the pins line up. Twist the solder tabs on the heat sink to secure it's position. Make shure all pins are present to solder in place on the bottom side.
    Dec 05, 2006 | Sony KP-43HT20 43" Rear Projection...
    Dryers Logo
    59 people viewed this question
    Top Dryers Experts
