Question about Harman Kardon Audio Players & Recorders
The cooling fan does not seem to be running in my avr347 amp, should it be running when unit is operating? Dont want to damage anything.
    Master:
  • 623 Answers
It is probably thermostatically controlled. But, I would check with an H/K dealer or repair shop to be sure. You don't want to have a thermal runaway disaster with the amplifier components.
Posted on Nov 29, 2014
Haier commercial cool portable ac unit makes super high pitch noise on all settings & returning it for repair is not an option what troubleshooting steps can I take? Ac blows cool & fan runs at...
It may be the bearings in the motor are dry or out. You coulod pull the motor and fan assembly out and check its operation while it is out of the heater case. Look for anything inside the heater cavity where the motor sits for any problem hindering motor operation.
Jul 01, 2012 | Cars & Trucks
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
My daughter called me this am from school. She said that her laptop seemed to be running hot, especially on the left side, and would shut down after about 15 minutes of use. I told her to run portable...
Joe- This does sound like thermal shut down. Unfortunately what I would bet has happened, is your daughter uses her computer on the bed often, which picks up lint. This lint ends up plugging the intake port of the computer. I believe the A105 has access to the fans on the bottom pannel which is really helpfull otherwise you have to take the laptop apart. you should get in there with a brush, a vaccume, compressed air and really clean out the fans, and the fins of the heatsink. I would also pull the heatsink from the processor clean both the processor and heatsink with Alcohol and apply artic silver thermal paste to it as per the instructions. Now reassemble. It should be all set.
As for the coolpad, if the fan is running, which I think it is, it will help. IT will not solve the problem, and the chip will continue to overheat and shut down but take longer to do so.
Jun 16, 2010 | Toshiba Satellite A105-S171 Notebook
Running very hot and shutting down
You are running into a CPU overheat issue.
1. can you feel or hear the cooling fan come on at all? If so try and use compressed air can to clean it out.. they get tremendously dirty. You can also try a vacuum hose, but cover nozzle with hand and only hold next to cooling fan outlet and nowehre else with laptop off and unplugged. Dont get near keys or other parts as will damage. Dont use SHOP VAC either.
2. If Cooling fan is NOT Coming on you can try a laptop cooling pad. these are external units by Targus and other companies that have cooling fans to supplement a laptop units cooling fan. You can try this to see if airflow is your problem.
3. If you recently ran encryption software, a new antivirus program, or upgraded to Windows 7 it is possible that your culprit is the unit is not cycling. Meaning the hard drive is continuously being accessed and the CPU is in constant service... this can cause overheating as well.
Jun 02, 2010 | Toshiba Satellite A135-S2276 Notebook
Sat highway speeds in cool weather the temp. lite
If the fan is not operateing you might want to run power directly to it from another power source ie a booster pack or another battery if you find that the fan operates then you wil need to be checking wireing & relays
Apr 22, 2010 | 1998 Honda F6 C Valkyrie
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Cpu fan malfunction
Hello Chris....i highly recommend you dont "pry" on anything and it have it serviced by a qualified tech. The vaio incorporates the heatsink and fan as a unit, It's a 2 wire fan that is temp. controled from 5v and up. You can take a vacuum and place at the ventilation opening and remove some of the dirt & dust that has accumulated inside, this will help. The cost is around 100 buxs for a new fan & sink...Sony part # 1-763-483-12. Attached is a pic of the unit..; Also note: a depleted battery will effect fan operation as well.
Hope this helps and will fixya up....
May 18, 2009 | Sony VAIO GRV670 Notebook
74 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
