Question about Lexmark "c950de color laser printer"
How to calibrate touch screen Lexmark printer c950
I want calibrate touch screen Lexmark printer c950d
While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 test...
I think you'll have to run a factory reset.
However, I cannot find any way of carrying this out. You'll need to contact Ricoh or their dealers, I'm afraid.
Feb 18, 2015 | Ricoh Office Equipment & Supplies
Touch screen blocked
The touch screen could have lost its calibration, but there is a good chance that it is bad, and needs to be replaced. To calibrate it, push the yellow clear modes key, then the numbers 1, 9, 9, 3, then push the red "Clear / Stop" key 5 times, and choose number one. Follow the prompts. Use a stylus or other dull pointed item. If you don't get a response, you need a new touch screen.
May 22, 2014 | Ricoh Aficio 450 Copier
Touch screen not responding
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
Mar 12, 2014 | Ricoh Office Equipment & Supplies
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
Calibration for 8060 touch panel
Press and hold down energy saver button and function button together then power on the machine. keep on holding the two buttons the machine will once show screen calibration marker then again show the calibration markers now touch the shown marker it will go to a new place keep on touching the final marker will be at center of screen . after touching it the calibration completes
May 05, 2011 | Panasonic Workio DP-3530 Copier
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
Lanier LD435c touch screen is not registering touch in right plac
Press the yellow clear modes button then press
1 9 9 3 and the red clear/stop botton 5 times
this will open up the touch screen calibration menu
select calibrate touch screen. follow on screen directions.
Good Luck
Apr 08, 2010 | Office Equipment & Supplies
Touch screen on hp laserjet m 3027 mfp not working
turn of the printer. Hold the C and # buttons and turn on the printer. When the screen goes black it will be ready to be re calibrated. there is a white dot, touch it with a pen, another white dot appears, touch it with a pen. It will continue to turn on now with a newly calibrated screen.
Dec 26, 2008 | HP LaserJet M3027 MFP Printer
Lexmark "c950de color laser printer" Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
