Question about VillaWare Kitchen Appliances - Others
How do I clean some burned on grease from the non-stick surfact
A "tuffy" scratch pad. I have very lightly used Soft Scrub.
    Top Expert:
  • VillaWare Master
  • 45,139 Answers
Villaware might be able to offer some advice but, in general, damaged non-stick surfaces require recoating which can be an expensive process.
Posted on Nov 29, 2014
Removing baked on spray non-stick coating
Hello, Donna -
There are several web sites with advice on cleaning cookie sheets.
More than one site I found recommends the cleaning method here:
https://lifehacker.com/baking-soda-and-peroxide-get-the-grime-off-of-cookware-514065732
I also find the commercial product Soft Scrub (found in the Household Cleaning aisle of most US grocery stores, where you will find dish detergent) excellent in cleaning most "crud" off cooking utensils. I use Soft Scrub and a plastic mesh scrubbing pad.
Bar Keepers Friend (also found in the Household Cleaning aisle of most US grocery stores) is also an effective cleaning product with a plastic mesh scrubbing pad.
Jan 05, 2018 | Kitchen Appliances - Others
What chemicals can i use to clean my gas braai,
I apologize I do not know what is a "braai" but since the category is "grills & smokers" I will proceed as though you were asking about a BBQ
Generally it is safe to suggest non-toxic cleaners like Simple Green because there is almost no chance of being harmed by this non toxic cleaner. However, non-toxic cleaners will need a lot of rubbing and scrubbing ad we usually want a chemical because we do not want to spend all day rubbing and scrubbing. Right?
We have been cleaning, maintaining and repairing barbecues for over 15 years and I still like Easy-Off a lot. Easy-Off is toxic but that means it will break-down greases and dirt and old marinades so they appear to be melting off the grill parts.
Please be sure to only scrub or brush grill parts made of materials that can be treated thus because coated grids (for instance) should not have abrasive brushing or the coating will scratch and oxidation occurs. Use heat, rough, green, 3m pads and degreaser for full safety and wire-wheel or sandpaper for real American stainless.
Anyway, I still like Easy Off after a very long time using hundreds of different agents. However, after cleaning make sure to clean-off the chemicals or burn-off for at least 10 minutes. Chemicals can keep you in the bathroom all week so be sure to rinse if you can (infrared burners cannot get wet) or burn-off the parts so there is no residue of the cleaners.
Feb 09, 2014 | Grilling
I had macaroni stick in one of my pots, how do I get it clean. It's blk inside the pot,
To remove stuck on food use water (the world's strongest universal solvent). But add a degreaser. Degreasers change the surface tension of water molecules to make the water droplets much smaller. Once they are smaller they can get into areas to start dissolving what it could not approach previously. Detergent being a surfactant also allows mixing oils and water. Hot soapy water works better. We used to use boiling water in a chinese restaurant i used to work at. Boiling water helps alot. Since your food is charred it is more likely carbon sticking to the non-stick surface. Your non-stick surface must not be non-stick anymore due to using the wrong chemicals or pads on it. High temperatures make silicone type non-stick coatings fail too. If there is no more non-stick coating to worry about you could use an oven cleaner. Oven cleaners are made of caustic soda or lye. Lye is made from common table salt (sodium chloride) Oven cleaner is great at attacking carbon but not very friendly to aluminums or the finished paint on any metals on appliances. Use your own discretion.
Mar 21, 2013 | Cook's Essentials CooksEssentials 3 Quart...
How do you Clean Toastmaster 218? what's the Trick?
Be cautious whencleaning..take note of this, UNPLUGFROM ELECTRICAL OUTLET BEFORE CLEANING. NEVER IMMERSE APPLIANCE IN WATER OROTHER LIQUIDS. ? While grids are still warm, brush with clean,soft pastry brush or cloth. ? Donot use steel wool or coarse scouring pads. Remove stubborn ? >stains with a plastic mesh puff or pad. For best results, use only products with directionsstating safe for cleaning non-stick surfaces ? Theexterior finish should be cleaned with a non-abrasive cleaner and a soft, dampcloth. ? Close latch and stand on end for storage.
Nov 21, 2010 | Toastmaster 218 Cool Touch Waffle Maker
Recomended cleaning for kitchen porcelain sink
Scouring powders or cleansers contain abrasives commonly used to clean and remove stubborn stains that are slow to respond to chemical action alone.
However, use of an abrasive cleaner may scratch and damage smooth finishes such as porcelain, fiberglass or enamel making it even more difficult to clean the surface in the future.
New kitchen and bathroom fixtures do not require a scouring cleanser to clean them of soap films and body oils. Dissolving soil by soaking with the correct non-abrasive cleaner (especially a foaming type that sticks to the surface) then wiping and rinsing usually does the job.
When cleaning older, abused fixtures, choose the mildest abrasive cleaner available such as a Soft Scrub -type product or baking soda, and apply just enough that, with light pressure, the embedded soils are loosened and may be rinsed away.
Aug 21, 2010 | International Thermocast Corp Thermocast...
Cleaning black cooktop surface - what products to use.
It is recommended that you use a straight edge razor blade and push in one direction to remove anything stuck to the surface of a glass cook top. Stubborn, cooked on, substances can be cleaned by scrubbing with a light abrasive cook top cleaner and/or a green kitchen scrub pad. The green srub pads are considered non-abrasive and safe for cook tops. You can also use liquid dish detergent (such as Dawn) to break through grease and grime. DO NOT use steel wool, SOS pads, or any scouring powders. These products can permanently scratch or dull the finish on your cook top. If you have any questions please let me know. I hope you find this information helpful.
Apr 27, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
How do I clean the inside of the microwave? It is
DO NOT use SOS pads! They are made of STEEL WOOL and will remove the protective finish inside the oven cavity. Without the protective coating, the microwave can arc internally and ruin the magnetron. Use the green scrub pads you find in the dish detergent section of your local grocery store. They are considered non-abrasive. Use the green scrub pads along with a non-abrasive cleaner such as Soft-Scrub or 409. Wipe clean with a fresh water and dry with a clean cloth.
Jan 30, 2010 | Sharp R-1505 Microwave Oven
Scratches on granite kitchen worktop
yes...believe it or not, T-CUT car polish...it really does work, even removes scratches from cd's, and scratches on the plastic wind deflectors on car windows
Sep 06, 2009 | Stone Clearance: Black Granite Vanity ...
How to maintain cleaning and scratch free black sink,my sink has spots and scratches on it. how to avoid these problem
Using soft scrub or some brand similar is the best thing to use. Manufacturers reccomend only soap and water, but soft scrub is best. Be sure to never use abrasives on any fixture, it will scratch and void warranty
Kohler makes a cleaning agent for cast iron sinks, if this is what you have.
hope this helps
Apr 14, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Kitchen Appliances - Others Logo
218 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Angel Joseph Jr.
Angel Joseph Jr.
Stan Ford
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
