Question about Microwave Ovens
Why do 3 out of 4 lights on a wacker neuson ltn 8 light tower keep going out? they will start they will almost reach full brightness and then clink off. till they cool down and then they will do the s
If I change all the bulbs then they will work for a couple weeks then its back to the same old thing. these are 1000 watt bulbs not cheap. it must be something else..
  • 44 Answers
Is the generator producing enough power? (8KW, 120/240V, 60Hz)
Has the circuit been checked for shorts?
Are the bulbs Spec or are they aftermarket?
Spec manual link below
http://products.wackerneuson.com/SpareParts28/wacker_direct.jsp?command=machinesearch&extRegId=w1&extlangId=en&urlAccess=true
Posted on Nov 29, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Posted on Jan 24, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Light Bulb Change
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Feb 03, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: 40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Posted on Feb 14, 2009
SOURCE: Maytag microwave light bulb MMV5207BA/BC
A 20W, 120V replacement xenon halogen bulb with G8 base can be purchased from Lowe's.
Posted on Apr 21, 2009
  • 72 Answers
SOURCE: Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Posted on Feb 06, 2010
Whirlpool microwave press light it diplays half or full or off???
That is referring to the under the microwave light that shines down on your stove. You have full brightness, half the brightness, or the light will be off.
Mar 06, 2015 | Whirlpool Microwave Ovens
Whirlpool - troubleshooting
That is the power level or brightness of the light setting.
Aug 08, 2014 | Whirlpool WMH31017AB 1.7 cu. ft. Microwave...
Hello, We received a Magic Chef Microwave Oven, MCD1110WB / MCD1110BB yesterday (8/31/11) to use in our workplace kitchenette. We are accustomed to having the microwave light come on when any...
We have the same oven, and the light comes on only when the oven is operating. When the door is open, the light is not on. I would be interested in knowing if anyone has done a work-around to make the light come on when the door is open.
Sep 01, 2011 | Microwave Ovens
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
After turning the bright light on above the stove
You may have shorting keypad or a problem on the control board.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please reply back directly to me for free help and tips.
Please include your full model number and color.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller
prototech@usa.net
Oct 05, 2009 | Kenmore 62622 Microwave Oven
Light under unit stays on
open the oven there are two or three safty switches near door one of the switch is for light if it is short then only light will remain on.by opening door light should come on set the time and hit start light will come again. replace that switch and it will be ok
Aug 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Sharp R-510 FK dangerous noise
Hello. To me, it sounds like something is stuck to the inside of your cavity and it is arcing, as you are seeing a bright flash, and hearing it. I would take apart/clean everything inside the cooking area, something is causing a problem in there. Usually just a good cleaning is all it needs, as the debris is making a focus point for the energy. Try putting a small glass of water, only 1/4 full, and watch while you start it, to see where the arcing is, it won't hurt anything for a second or 10.
Hope that helped, and thank you.
Mar 29, 2009 | Sharp R-510HW Microwave Oven
Surface light "nightlight" will not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Feb 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1650 Microwave Night Light does not work
In your case, it may just be a shorted dimming diode, a black diode usually located between the light relay and the connector.
(Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
If it is shorted, you will have bright lights in both the bright and dim settings.
In case you or someone you know has the tools and experience to desolder and solder small components, the replacement rectifier diode is not critical and can be any of these:
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125 some of which are available form Radio Shack.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
William E. Miller
prototech@usa.net
Feb 13, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
