Question about Kitchen Ranges
Need stovetop knobs for Bosch hbn445auc . Have a 1" shaft
  • 15,557 Answers
How do I pull the wash selection knob off the panel?
If no set screw on knob, a slow hard pull will remove it from the shaft.
Feb 12, 2016 | Bosch Washing Machines
Where can I get a replacement "Oven Function Selector Switch" for a BOSCH OVEN - Model No. HBE632UAU/03 (Year of Manufacture 1991) Part No. 05 5870 which was later replaced by Part No. 05 9863. The...
try going to goole.com and put in appliance parts there will be a number of sites that will come up many in the USA that have many parts.
May 16, 2014 | Ovens
Heater controll switch
Hello, I want to tell you about some of the knobs for the temperature control switch, if that is the switch you are referring to.
The way some of the knobs are made, they have a 1/2 moon shape with a metal clip inside them on the backside of the knob. The 1/2 moon shape is also present on the control shaft the knob fits onto. When the knob breaks and splits, the knob rotates around the temperature control shaft without moving anything. From the driver's view, the knob is normal.
You would need to pry off the knob and inspect it, then rotate the temperature control shaft with your fingers or lightly grab it with pliers.
Jan 30, 2014 | 2004 Ford E-350 Super
Stuck action
Stuck Knob Solution here! Hello, I had the same problem and found the perfect solution online (for just $2.99): In order to fix this problem you just need a larger knob which provides the extra leverage needed to (effortlessly) turn the knob. The original knob should come off easily by wiggling and pulling at the same time. The knob is attached to a 1/4'' shaft so any lager knob that fits a 1/4'' shaft will do fine. I used one from radio shack (Model: 274-407), which was 1/4'' shaft and it also contained a micro screw that you can tighten to ensure a snug fit. This knob slightly covers the labels (ALT,VS IAS, etc) but because these values show up on the screen as you tune to them, it's no big deal for me. Btw, I attempted to contact Saitek for a solution and shocker! -No Response.
Dec 25, 2013 | Saitek Pro Flight Multi Panel (PC) Flight...
Can't find replacement burner knobs for my PGL985UC Bosch stovetop gas stove
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 21, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
Replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Jan 01, 2010 | Kitchen Ranges
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
