Question about Kenmore Washing Machines
11044832200 kenmore elite he3 drum bearings do you have these
  • Kenmore Master
  • 15,557 Answers
SOURCE: Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Had same problem. Followed advice on post (i.e., remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter and voila!). Found one sock, a quarter, and some other junk clogging the drain. Saved $55 house service call. Thanks all!
Posted on Dec 13, 2007
SOURCE: Kenmore Elite HE3 washer
I found when mine doesn't drain there is a sock blocking the drain holes. Open the door and pull out the rubber gasket at the bottoma nd there should be around a half a dozen holes. Good luck!
Posted on Feb 21, 2008
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
onthejob5130
  • 640 Answers
SOURCE: kenmore elite he3 model # 11044832200 gives me a f15 error code.
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Posted on Dec 26, 2008
  • 107 Answers
SOURCE: Kenmore Elite HE3 water is leaking out the front
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
Posted on Mar 17, 2009
I have a Kenmore Elite He3 model 110.44832. I ran
Open the top and inspect the damper mechanisms that control drum motion in various directions. There may be broken pieces, or just something out of position. Hope this helps!
Jul 01, 2010 | Washing Machines
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 19, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Oct 05, 2008 | Kenmore 82822 Electric Dryer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
How much play in rear pulley
Scott, the pulley should be tight, no play, Check to see if one of spokes are cracked on the pulley. I do believe that you have a 5 year warranty on the bearings on this machine, parts only. It's a huge job to replace the bearings on this model. Give Sears a call to see if they will cover the parts. You will need the rear tub and bearing kit...Good luck
Jun 21, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
164 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
