I have an error code 3807.previous message said needed an alignment
Turned off and on. still does not work
4 Suggested Answers
SOURCE: printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Posted on Feb 22, 2011
bronk50
  • 27725 Answers
SOURCE: My printer has stopped printing
not match the destination list of the printer ... dd/yy or dd/mm/yy, depending on the country code. ... Error 3807
http://support.microsoft.com/kb/186547
The AT schedule file is corrupted. Explanation: This message should occur only on a down-level computer. Any action to correct the problem should be performed on that computer. The schedule file is damaged.
Action: Restore the schedule file, Sched.log, from a backup copy, or delete the file and create a new one with the AT utility. Sched.log is in the LANMAN\LOGS directory.
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart hope this helps
Posted on May 16, 2011
SOURCE: My printer ESP5 shows an Error code 3807. I do
Please tell me what to do my printer says code 3807 on the screen & will not go away.
Posted on May 27, 2013
What is error code 3806?
Error Printer error 3806 3807 3808 3809 3810 or 3811
Kodak does not say what the error is but they do show how to deal with it.
Nov 29, 2015 | Kodak ESP Office Equipment & Supplies
Why is my kodak 5250 showing error code 3807?
Error: "System status failed" (3807) Published 08/25/2010 11:38 AM ' Updated 08/28/2012 05:23 PM ' Answer ID 1249
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary
  1. Open the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error is resolved, upgrade your printer firmware:
  1. Locate and select the firmware for your printer.
  2. Follow the on-screen instructions to install the firmware.
If the error is not resolved, contact us.
Jul 01, 2014 | Kodak ESP 5250 All-in-One Printer
Why is my kodak 5250 printer showing error code 3807
http://support.en.kodak.com/app/answers/detail/a_id/1720/~/error%3A-printer-error-%283806,-3807,-3808,-3809,-3810,-or-3811%29/selected/true
To resolve this error:
  3. Connect the power adapter to the printer. Turn on the printer, if necessary.
  5. If the error is displayed, contact http://support.en.kodak.com/app/contact/src/gocontact/selected/true
Error message 3807
Go to Kodak site. The error message means system failed. You will need to unplug the printer for at least 30 seconds and then plug back in. You also may need updated drivers.
Apr 13, 2014 | Kodak ESP 3250 All-in-One - Multifunction ...
Printer error error code 3807
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Maybe the printhead is not working properly. call Kodak and they will going to replace tht printhead. Thanks
Sep 01, 2009 | Kodak Office Equipment & Supplies
What is an error 3807?
If this error is from your printer itself, This error code means that you need to replace the Printhead. Call Kodak so that they can process a replacement for you 1800 421 6699
Thanks
Aug 24, 2009 | Kodak ESP 5 Printer
Does anyone know what error code 3807 on a Kodak ESP 5 all in one is? And....can anyone tell me why the dammed thing tells me the print head is not installed every time I turn it on?
found a solution for your error code 3807 "System status failed"
To resolve the error condition:
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
If the error condition continues:
  1. Remove and install the Printhead two times before closing the Printer Access Door.
  2. Wait until the printer is ready to use.
If the error is not resolved, contact Kodak.
Jun 21, 2009 | Kodak ESP 5 Printer
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
