Where do i find a remote controll for visco model vsc-32v1?
I do not have the remote and my 32" flat screen has a blue box on the screen that i can not get rid of, picture inside a picture.
  • 1,253 Answers
Visco is a value brand, originally built by mitsubishi/nec. When the major companies supercede their sets with newer models, they strip down the original design and put them up for contract to be marketed by third parties. Same basic guts as the polaroid sets. Directv lists a remote code, 10810, for these sets, so you should be able to buy a universal remote that will work this set. It would be much cheaper than trying to find an original remote.
Posted on Nov 29, 2014
3 Suggested Answers
kdbonhamee
  • 11 Answers
SOURCE: I have a VISCO VSC-32V1 ser # 64232104307 that has
These sets are identical to polaroids, which are terrible. I would not recommend fixing it. They are poorly designed. Parts are hard to come by. It sounds like a video board problem.
Posted on Oct 06, 2010
  • 905 Answers
SOURCE: Hi I have a VISCO
The orange light typically indicates that it has not detected a video signal. Using your remote, or the front panel buttons, try changing the input source to a known working input. Make sure that your cable from your receiver / dvd player / etc hasn't come loose.
Posted on Feb 13, 2011
Visco tv
How do i program my dish network remote ?
Answer The instructions for programming your dish network remote completely depend on the model of your remote. The model of your remote is more than likely located on the back of the remote. You can find more information here:http://tech.dishnetwork.com/departmental...
May 13, 2014 | DISH Network Televison & Video
My tv keeps flickin on and off. sometimes the remote works and sometimes it dont.what can i do?
Hello Malcolm,
That model is sold under several different names but the same model number. These units are well known to have issues with the power supply board and this can cause the exact symptoms you are having. The power supply board can easily be repaired, you just need to replace the defective capacitors on the board. Here is a link to a repair guide for the Visco TV that is the same as your Polaroid model. The repair guide shows what to look for and replace on the power supply board to repair it. I hope this helps.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
BuddyMc
Jul 20, 2012 | Polaroid FLM-323B Television
I have a VISCO 32' tv & lost the remote. Model # VSC-32V1. I need a remote to use to get to the HDMI area. I tried a universal but it only turns it on & does channel.
Check the operation manual and note down the model number and go and fetch it from any electronics shop nearby. These are available freely now in the market.
Jul 19, 2012 | Televison & Video
Polaroid FLM323B,power board What is the voltage at these pins?
Check the caps on the power supply board, this is the most common problem with this model. Here is a link to a repair guide for a TV that uses the same power supply board
I hope this helps, if so please rate my solution
BuddyMc
Jan 24, 2012 | Polaroid FLM-323B Television
Screen isn't blue when you turn on its white
The most common cause of white screen and no picture problems on this unit is a failure of the power supply board. Here is a repair guide with full dis-assembly and repair instructions that should be able to get you back going again. This guide is for the Visco TVs but the boards are the same as the Polaroid model
I hope this helps, if so please rate my solution.
BuddyMc
Dec 25, 2011 | Polaroid FLM-323B Television
Have direct tv remote, and lost the remote that came with my Visco TV, there is no code in the direct tv system, so can I program another brand to substitue for my VSC 32V3 model tv
Use POLAROID and click u don't know the model number...the screen will go black for a second then ask u to press volume ... first one won't work so click on try next code...it will finally work on like 4th or 5th code
Aug 20, 2011 | Televison & Video
Can't find book for my Visco Codes, need codes to program into remote control.
I wasn't sure of your model, but the manufacturers pretty much keep the same codes from model to model. I found a free downloadable Visco instruction book and the remote codes start on page 42. I'm not sure if it is what you are looking for, but hope it helps.
http://content.etilize.com/user-manual/1010558313.pdf
Aug 11, 2011 | Televison & Video
Hi I have a VISCO Flat screen tv MOdel#VSC-32v3 we turn tv on and the orange light is on but no picture does the tv need reset
Feb 13, 2011 | Insignia IS-LCDTV32 32 in. Television
Tv will not turn on. power light flashing red and blue. june@thecellulitesolution.us
This model uses the same power supply that is found in many of the Polaroid TVs. The board is model MLT070AX. The failure you are having is a common problem with this board. The repair is easy if you can solder. Check out this link to an article about how to do the repair.
I hope this helps, if so please rate our solution.
BuddyMc
Jan 16, 2011 | Element Electronics FLX3711B 37 in. LCD TV
I have a VISCO VSC-32V1 ser # 64232104307 that has no picture< just a blue screen. VISCOs phone number is disconnected. Is this HDTV worth repairing? If worth repairing are there parts available?
Jul 25, 2010 | Televison & Video
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
