My hard drive has system but when i try to boot from usb or cd room for new system it's freeze and doesn't start up with usb boot or cd room
I tried to rest the bios and take all components off the motherboard still nothing happen just freeze on cursor flashing but not enter to the boot menu or starting the setup for the new system... but when i release the devices such like usb or the cd its working normally boot to the system i installed before thanks
    Sergeant:
  • 269 Answers
You didn't provide any details on what OS you are running or trying to load, but here are some steps to verify.
1. Ensure that the procedures you used to create your bootable USB device or bootable CD are correct. These will not boot unless they have a boot loader installed properly on them.
2. While running your existing system, ensure that you can actually view the files on your USB device or CD (in case either device is not actually working).
3. Ensure that the BIOS settings set the boot priority to USB or CD ahead of the hard drive.
Posted on Nov 29, 2014
sandrew
  • 2961 Answers
SOURCE: Freezes @ Mobo Splash Screen
you have i would say a corrupt bios, if it can't even select the splash screen, i'm assuming that you have tried to reset the cmos by means of the relevant jumpers, either JBAT1, CLRCMOS or CLRCLK or similair. If so and still nothing, when you built the system you may have stressed the board fitting the heatsink and fan or the memory causing the mobo bios chip to fault or it is simply a manufacturer fault and therefore up for exchange of faulty goods.
Posted on Oct 02, 2007
ahmdrgb
  • 5 Answers
SOURCE: Does not display setup or boot menu
first try to clean you mother board with anty dust spray
secound on your motherboard you can see clear comos junber behind the battery comos try to clear it ...... i think your motherboard will workink after that
Posted on Jan 19, 2008
SOURCE: problem regarding usb booting
the hard drive registered in the standard cmos utility is the only one that could be registered for boot in advanced cmos setup and no other, if your usb hard drive and pen drive could be registered in the advanced cmos setup - where boot options are registered, surely it will boot your pc.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Posted on Feb 19, 2008
marked
  • 6487 Answers
SOURCE: Booting up new motherboard
You need to check that your media like CD-ROM is in a proper jumper settings because it not being detected by your pc check this link http://www.mysuperpc.com/pc_assembly/computer_install_cdrom.shtml
then try it again.......
Hope that helps........
Posted on Jul 05, 2008
  • 362 Answers
SOURCE: I am using a MS-6309 N1996 Ver 1 motherboard...how
Hello, you usually press 'delete' or maybe the tab key on power-up. Try and read the message that will flash up on the screen, usually momentarily, just before it starts to boot. Instead of powering down then back on, press your 'restart' button then you might see the messages that you may have missed if your monitor was still warming up. Regards, nicam49
Posted on Jan 22, 2011
New hard drive will not boot up on compaq cq56
Hi Lucas.
The situation could be one of several things, depending on how the hard drive is attached to the computer.
  1. Inside. You had an old hard drive. you opened the computer, took the old drive out, put the new drive in, and turned it on.
  2. Inside - you had room for two drives and added this second one.
  3. Outside. You've hooked the drive up with a USB chassis and cable.
I'll start with lowest level, and my apologies if i include things that you're rolling your eyes about. Some folks know it inside and out, some don't.
  1. The new drive needs to have an operating system (OS) installed that works with your laptop (i.e. something like Windows or some flavor of Linux). Unless prepared ahead of time, the disk is just a place to store stuff. it will need to have the OS installed first before it can boot your computer up. This is the case, you'll need to start with OS install media (you should be able to boot off that from CD ROM or USB. From there, it'll give you instructions on how to load the OS onto the hard drive.
  2. The drive has an OS on it, but your computer may not know to look at that hard drive. In the early boot-up process, that is driven by the laptop firmware, there are set-ups for what order things are searched for boot media. You'll need to pause bootup early - it'll usually flash by and you'll likely press F2 or F4 to get into the setup menus. If, say, there's a CD rom in your CD drive, and the menu is set to first look for boot media on CD, then from Hard Drive, then it may go there, not be able to boot from the CD since it's a music CD, and stop. Or conversely be set to go to the HD first, not see it, and stop. You'd need to alter the boot order then to see if you can get the drive talked to .
  3. Also in those menus, there may be multiple SATA connections, that can be turned on or off. You may have to go through and enable the connection to that drive to ninny-slap the firmware in bothering to talk to it.
  4. Drive is in an external USB chassis. - Here again, you may have to go tell your boot firmware to enable, or add priority to booting from a USB device. Factory defaults are often 'no' to minimize vunerability to random malware on thumb drives.
  5. Hard drive is formatted, but not to what your PC can read. if it was, for instance, formatted for a Mac, the OS may not be able to deal with it without re-formatting it to something like FAT32 or NTFS. You'd need to start with the Hardware manager disk utilities to see if it can even see the disc (though you'll need a working OS to do this)
  6. You can also try moving the disc to another system to see if it works there. if it does, it could be that the connection in your computer is broken or not connected well.
  7. If this is right after a new OS install, sometimes this can be a bit confusing for the OS the first time it tries to boot. You might want to try booting in Safe mode to see if it can bootstrap it's way up. It may be needing to do a ton of updates and driver downloads.
That scratches the surfaces. having been through all variety of good and bad disc install experiences, I'll mostly counsel patience.
Good Luck!
D
Dec 03, 2015 | Compaq Presario CQ56-115DX Laptop
HP nc6230 freezes shen loading Windows XP Pro
Try booting from your Optical Drive. First insert your Windows XP Pro CD into the drive. Do not re-install the operqating system or you will lose all your files and programs! When prompted press 'R' to use the Recovery Console. You should be able to write a new boot sector to your hard drive.
If this doesn't solve the problem, you might need to re-install the operating system. If you can find a way to save all your files from your drive (perhaps by putting your drive in an external USB caddy and viewing its contents on a different computer).
If all else fails get a new hard drive and start again with your WIndows XP Pro CD. Use an external 2.5" USB caddy afterwards to get your documents and files back off your old disk. You will need to re-install your programs, though. If your disk is Service Pack 3 you should be able to get straight back on the internet via a wireless connection to update all your drivers from hp's website.
Oct 27, 2011 | HP Compaq nc6320 Notebook
Non system disc or disc error fix
Hi, do you have a floppy disk, cd or usb stick inserted in your computer? Try removing such items and reboot as it may be trying to read these before the hard drive.
Check the boot order, when you first turn on your computer, access the BIOS menu (may need to push Delete, or one of the function keys eg F2, F8, F12 etc).
Check the boot order to ensure the correct hard drive it listed. Try moving the hard drive to the first option and reboot.
If removing any cd, usb stick etc doesn't help, try removing the hard drive and see if you can access it from another computer. If you can't access it, your operating system nay be corrupt and you may need to reformat.
Jul 28, 2011 | Intel Motherboard
Hi my acer is asking for boot device
hi there,
please make sure that there is no USB flashdrive connected on your computer and make sure that there is no cd in the drive.
It's saying that it cannot find a bootable device because the drive it's trying to boot from doesn't have any bootable file.
If there is no cd in the drive and no USB flashdrive is connected chances are that your operating system installed in the hard drive was corrupted and you may have to do a reinstallation.
Hope this helps!
Jun 25, 2011 | Acer Aspire 3000 Notebook
The computer could not make booting from cd . and the window xp which is installed could not continoue to start but it is allways restart in the middle of the process
have you check your bios set up to make first boot as cd room?
press delete or f2 button when the computer start go to booting selection and set first boot to cd room, if you have done this way and still won't boot try to change your cd room or windows cd, it seems your cd room or windows bootable cd is bad, and also try to clear your memory (ram) by erasing your ram from dust by using a pencil eraser, to fix your windows problem without re-install your windows you can try to put your hard drive (which contains windows xp) in another usable computer, make it as secondary master or slave (to do it you can replace cdroom and change with your hard drive) ,after that you can check on my computer tab if your hard drive has detected. check in what drive is your hard drive (for example d)then go to run type cmd, type your drive which contains an error windows (D:) after the path was located to D: (your hard drive that contains an error windows) type chkdsk /f /r then enter, wait till the process done, it will take about 20-30 minuets and it will repair your windows
May 22, 2011 | Computers & Internet
Hello All, My dell latitude e5510 freezes when I try to play some videos, it may work for some time but it freezes after some time. This happens quite more times and I can only exit form the situation...
The laptop may be overheating. Check that all vents are clear and dust free. Listen for the internal fan. This should operate only occassionally. If it is operating all the time and speeds up just before the laptop freezes then something is causing the laptop to overheat. If the fan cannot be heard at any time, then the fan may be faulty.
May 17, 2011 | Dell Latitude - E5510 Laptop Computer...
Reboot and select proper boot device or insert boot media in selected boot device and press a key what does this mean
This sounds like the starting screen when you re install an operating system on your computer. I would first try to exit out with the ESC key, Exit with out saving. If that doesn't work correctly, try unplugging the Pc and restarting. Hope this helps!
Best Wishes and Good Luck!
May 05, 2011 | Acer AspireRevo 3610U2002 PC Desktop
Windows Server trying to boot from external hard drive
go into your 'update settings'. there is a section of where it asks you about how you want your settings set and where to send updates to. You may find the problem here. Check all the 'advanced' settings as well. If your Western digital is plugged in via USB and not requiring updates, unplug it while starting your system, after complete start up, reinsert the USB plug. It may show new devise found, then from here, you may be asked to reinstall it to stop the rebooting.
Aug 24, 2009 | Western Digital My Book Essential Edition...
Gateway MX6927 Windows Xp won't boot
put your xp disk in the optical drive.Turn off computer. Turn computer back on as soon as you turn it on start tapping f 12 constantly.it should go the boot menu giving you a choice of booting from cd or hard drive choose boot from cd.Be sure you choose repair rather than new installation or you could loose all your information stored on the hard drive,I personally would try safe mode first you can get to safe mode by tapping f 6 when you first turn on your computer.
May 04, 2009 | Gateway MX6927 Notebook
Can't install xp - freezes
You need a CD/DVD USB drive.
Ask for one or use a HD 3,5" USB drive, open de HD USB disconect the HD and conect a CD drive, it will work like a CD USB drive.
Jan 10, 2008 | ViewSonic Tablet PC V1100
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
