Question about Ricoh Aficio SP C410DN Laser Printer
I have a printer that has only 15064 total pages printed. It is not communicating with my computer (Data In is not lighting up). This is my 4th of this printer and if I plug in the exact ip address
I have a printer that has only 15064 total pages printed. It is not communicating with my computer (Data In is not lighting up). This is my 4th of this printer and if I plug in the exact ip address of my other and plug it in to use it still does not work. Is this a motherboard issue? Can I take the motherboard out of one of my other printers that still work but have basically worn out (over 350,000 copies)? Where do I find the info that will guide me through switching it?
    Habit-Forming:
  • 45 Answers
Delete it from the device manager and shut down PC . It should " re- discover the device and may solve your problem
Posted on Nov 29, 2014
Testimonial: "Nope - did not work. However, I was able to take the control board from one of my old ones and plug it in to make it work great. The bad thing is that the new printer now has the "counts" and info from the old worn out printer. Not a problem now but it will be once the printer wants new supplies (PCU, etc.) installed because the counts tell it the time is up for the consumables. Any idea how to work around this?"
  • Sondra Adrion Davis
    Sondra Adrion Davis Nov 29, 2014
Bubbabear64
  • 2794 Answers
SOURCE: Revised IP address for Ricoh 2020d
Go to user tools counter. Go to settings. Go to interface. You should see the IP address settings window. Some Ricohs have auto DHCP. Usually I turn that on to get it to recognize your router. Make sure your gateway address is inserted as well.
Posted on Jan 11, 2009
  • 990 Answers
SOURCE: Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
Posted on Feb 13, 2009
SOURCE: access ip address inofmation page on aficio 3224c
Type the IP address of your machine into your web browser. Login to Administrator Mode as follows:
Username: admin (or possibly "administrator")
Password: (leave blank)
Posted on Mar 12, 2009
leroyal
  • 2120 Answers
SOURCE: Can't print to network printer
Click
Start
Run
cmd
enter
type ping (the printer's ip address )
enter
This will let you know if the network can talk to it.
make sure DCHP is turned off at the printer
Posted on Mar 13, 2009
SOURCE: Ricoh Adicio on a mac
You'll need to download and Install the "PPD" installer for your Mac OSx here, if you haven't already done so:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x2022_27/x2022_27en.htm
..... then (assuming that your Copier doesn't have Postscript installed - most don't) browse for the printer, but be sure to select the driver version that points to "pxl", and not a "ps", or "pcl" driver. "PXL" is the only language that will work with Mac if postscript is not installed on the machine.
Good Luck. Please rate me.
Posted on Jul 22, 2009
I moved my HP 4000 printer from one office to another. When I hooked It back up, it printed out a few pages of symbols and then will not print at all. The ready light is on, but it will not print. Any
If you get a bunch of meaningless symbols on the page the usual causes are a corrupt or wrong print driver, a bad communication cable or a failed formatter or possibly a print job stuck in a queue on the computer that you connected the printer to (pending jobs often corrupt when you reconnect your printer). Unplug the parallel or network cable from the printer and restart and then try to print the configuration page. If it prints then plug in the communication cable and try printing again. Still bad after that reinstall the printer driver. If a fresh driver does not work, try a different cable.
Sep 17, 2014 | HP LaserJet 4000 Printer
MICRO 320 TURBO PRINTS JIBBERISH INSTEAD OF INVOICE
Check your printer driver and the communication cable. These are the two most common causes of this issue.
Aug 27, 2014 | OKI MICROLINE 320 Turbo Matrix Printer
Does not print
Epson sylus notorious getting getting corrupted software
1st Uninstall all Epson stylus printer software prividing you have instalation disk
Disconnect Printer
Restart computer and check to make sure under control panel / printers that there is no primary printer in there if there is delete it
2nd give printer power cable /communication cable good clean and check the printer port on computer isnt damaged.
3rd turn computer off reconnect printer have software ready but only if it is required most window systems have enough data with them that it will recognise new printer and install auto but if it asks for disk you will have it ready.
4th turn computer back on see if it notices new printer if not not to worry put disk in and install software,which will normally take you through a connect cables and power and install guide after that it should do a test print, if this comes out everything should ok again, but just check in control panel/ printer, and make sure its marked as default printer
hope this helps
Aug 12, 2014 | Epson Stylus Sx438w
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Dec 09, 2013 | Canon LBP6000 Laser Printer
Printer will not communicate with the computer
1. Walk over to the printer and print a test page directly. The procedure for printing a test page will vary from model to model, so you may need to consult the user guide that came with your printer. For most network printers, you can print a test page by navigating the "Information" menu on the control panel and choosing "Print Configuration" from the menu. For many desktop printers, you can print a test page by holding the power button until the page begins to print. If you can print a test page from the printer, but not from the computer, you know there is a communication problem between the printer and the PC.
2. Remove the printer cable from the back of your printer and the back of your computer. After the cable has been removed, carefully put the cable back into place, making sure that the printer cable is tight. If your printer uses a parallel cable, be sure that it is fully seated on the back of the printer and on the computer. If you are using a USB cable for your printer, be sure that the tab is fully seated in the computer, and that the square end of the cable is firmly connected to the printer.
3. Power down the printer, the restart your computer. Click on the "Start" button and choose "Control Panel" from the menu. Double-click the "Printers and Faxes" icon, locate your printer, right-click on it and choose "Properties" from the menu. Click on the "Print Test Page" button to send a test page to your printer.
4. Look at the network card on your network printer to see if there is good communication between the printer and the network. You should see a flashing green light on the network card. If there is no light--or if the light is amber or red--the communication is not happening. To test the network communication, remove the network cable from both the network cable and the network port on the wall, then reseat the cable and check the communication again. If the problem remains, you will need to remove and replace the printer's network card.
Aug 10, 2012 | Lexmark X4650 InkJet Printer
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
Ricoh Aficio  SP C410DN Laser Printer Logo
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
