Question about Jensen Car Audio & Video
My jenesen uv8020 wont power up i hit the rest buton and the blue buton lights turn on but turn right back off i replaced my front broken screen it powered up it worked for a 7 months when i would tu
My jenesen uv8020 wont power up i hit the rest buton and the blue buton lights turn on but turn right back off i replaced my front broken screen it powered up it worked for a 7 months when i would turn key on it would power off and power back on
  • Jerry Erler
    Jerry Erler Nov 29, 2014
    and my truck battery's went dead then it won't power on now
    Problem Solver:
  • 15 Answers
I need more info. Did you check the ground wire to make sure you have a good ground? Some installers try to rely on the antenna for a ground when hooking it up due to laziness and it will eventually burn the stereo out from low voltage, or, you could have amps that are killing the battery enough to drop the voltage down and it's killing the stereo. I have also seen ground loops kill stereos, but, I need a bit clearer info as to exactly whats happening to answer the question.
Posted on Dec 02, 2014
  • Jerry Erler
    Jerry Erler Dec 02, 2014
    hey mark my screen was cracked so i got a new replaced it it was working fine my battery went dead charged my batterys and my stero wont turn on i press the reset button the blue lights light up but it wont turn on lights go right back off so i took it back out i have a nother screen put it in and reinstalled it in my truck yesterday it turn on turn on my cd and it worked for about 2 minutes and then on buttons or touch creen would work so press the reset botton and every thing shut off now it wont come back on again checked all my wires its all hooked up right using the wires from my tuck radeo my truck is a 2001 f-350 with 7.3
2 Suggested Answers
SOURCE: the front screen wont power
There should be a small reset push in on the lower left hand on the monitor panel by the buttons. Press in a pen or paperclip to reset the system. If still nothing, remove the unit and verify that the power comming in from the hot line falls between 11V and 16V. If you do not have these readings then the problem lies somewhere in your vehicle wiring.
PS : just in case you dont have the manual to this one, you can click here for it.
Posted on May 13, 2011
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
Dvd player wont show picture
To fix this issue on the back of the double din touch screen#uv8020, splice the pink wire, and splice into the (black) ground wire connecting them together. This will enable you to watch dvd;s whie driving.
Jan 22, 2009 | Phase Linear UDV9010 Car DVD Player
Convergence issue Hitachi HDTV Model #53uwx10ba
you have a sensor problem to start magic focus is the last step in this repair done normally after replace converge outputs did you do this? if so a manual alignment is needed then you may write it into memory if you get a solid green screen after just briefly you have done it wright if you get a red screen after wards you need to try again it will stop on red if all is not well
Oct 08, 2008 | Televison & Video
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Toshiba a100 laptop
Definitely try without the battery. These models are known to have a "short" problem, usually with the palm rest, which causes this failure, although it usually is more sporatic, and doesn't happen 100% of the time.
Also, can you remove all but 1 piece of memory.
Good luck, and let us know what happens.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Polaroid flm 3201 wont turn on
If you have no power light at all on the front of your tv. Check the fuse by the power coard.
If you have a red light only and have the dark power board with black heat sinks. check the fuse in the center of the power board.
if the light turns blue when you hit the power button but no picture and have the dark power board replace the 2- 1000 mfd 10 volts caps with 2- 1000 mfd 16 volt caps at 105 deg.
need more help let me know
Nov 24, 2007 | Polaroid FLM-3201 Television
Car Audio & Video Logo
111 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
