Question about Philips HTL2101A/F7 Soundbar 40 Watts
Can't turn sound down...
The sound won't go down...
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Try a reset on unit and remote
Posted on Dec 01, 2014
The 'key in ignition' warning sound won't turn off and my battery went dead. How do I get it to turn off?
Pull the Battery Post off the Battery then the fuse If that don,t work Cut the Horn Wire To It
Mar 04, 2013 | 2004 Ford Windstar
Wont start
There is no sound to flooding &
there is no vapor lock in over 30
years, since all vehicles are fuel
injected & the fuel either continually
flows back to the tank or deadheads
to fuel rail & is used
You either have fuel pressure or
it is too low or not there or pump
drains down when turned off
You obviously need a good battery,spark
plugs & functioning ignition system (spark)
Will have to be tested to see what your missing
Could be you have a stored code if the electronics
are checked first.
You need to provide a vehicle,year,make,engine,etc
& some detail of any problems,plus any testing done
Won't Start --- won't get you an answer or a quess
Nov 16, 2012 | Cars & Trucks
Loud knocking
Sort of sounds like the timing belt broke-- if you have one
The valves may have hit the pistons & that is why it won't turn over
I don't know any of that is true & won't wish it on anyone,but
it is a place to start
Sep 13, 2012 | 2001 Saab 9-3
FS320 serger needles won't go up and down. New
if the machine is still under warrenty, take it back
if it's not under warrenty, take it to the place you bought it from & tell them
May 28, 2012 | Yamata Sewing Machines
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
My powerbass 150 amp was running perfectly one day, shut it off by the rockerswitch on the back to go to bed. Got up next morning, turned it on by the rockerswitch and no sound anymore, after about 5...
The problem with amps is they generate lots of heat when they are working and semi-conductors don't like heat, so overtime they fail. In your case either somekind of protection circuit has stopped an overload or one of the main semi-conductors that does the work has failed. It's off to the repair shop with it!
Aug 19, 2011 | Audio Players & Recorders
1) The lever at the back that keeps the foot up when threading etc will not stay up on it's own. When you put it up, it just falls bak down a second later. 2) The needle won't go up and down,...
it sounds like the take up lever has either come loose or is broken, & since the needle won't go up & down it needs to be checked
Aug 02, 2011 | Singer 1507
Philips HTL2101A/F7 Soundbar 40 Watts Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
