On the crew beta for ps4,on the main menu screen it says that the servers are down.why is that?error code num #0_1.
How do i remove the Cinavia code 3 from my PlayStation 4
Cinavia Message Code 3 Fix: How to fix Cinavia in PS4
www.cinaviamessagecode3.com/2016/01/how-to-fix-cinavia-in-ps4.html
I know the feeling when we are watching some movie on Sony PlayStation 4 and ... I have used below product for fixing Cinavia related issues my PS4 gaming ...
Ps4 cinavia fix.. - YouTube
? 0:45
https://www.youtube.com/watch?v=i37Y_lJwiKk
Feb 11, 2016 - Uploaded by Rocky Vik
Worked for me ..just change the audio language to other country as i ... a temporary fix but after go back to ...
Audio outputs temporarily muted Message Code 3 Cinavia - EASY FIX ...
? 1:04
https://www.youtube.com/watch?v=YQNrbFB0dbY Dec 25, 2014 - Uploaded by bigstackD
... get this message on copyrighted movies playing through PlayStation 3 ... temporarily muted Message Code ...
Cinavia Error Fix 100% Working Method for PS3 and PS4
https://www.techterrainblog.com/cinavia-error-fix-ps3/ Feb 7, 2017 - Here's a Permanent Cinavia error fix for PS3 and PS4 working in 2016. ... Getting cinavia message code 1 or cinavia message code 3 on your PS3 or PS4 ... my help in promoting his product to the masses in exchange for a ...
How to Get Rid of Cinavia Protection on a PS3 - Or at Least Bypass it ...
www.danrichard.com/.../how-to-get-rid-of-cinavia-protection-on-a-ps3-or-at-least-by... Nov 19, 2012 - How to Get Rid of Cinavia Protection on a PS3 - Or at Least Bypass it! .... Same here works for sound n code 3 but not playback stopped code 1 .... I'm playing a movie put on my drive and my PS3 is not connected to any kind ...
Sony Playstation 3, 4: Cinavia PS3 Fix - The Causes and the ...
playstation3an4.blogspot.com/2014/12/cinavia-ps3-fix-causes-and-antidotes-to.html Dec 10, 2014 - Cinavia PS3 Fix errors are errors that are brought about it.
remove the Cinavia code 3 from PlayStation 4 Google Search
Jul 11, 2017 | The Video Game Consoles & Games
The crew beta is not working for ps4
This has expired not but game is fairly cheap now.
Nov 29, 2014 | Sony PlayStation Video Game Consoles &...
How to Fix error code Ce-34878-0 on PS4
If you are experiencing this ce-34878-0 error code, please close the application and then install the latest system software and game patch. If the error occurs again, initialise the PS4 system after back-up of the save data and please also submit any crash reports after re-booting your console when the error occurs. Sure the "solution" isn't exactly helpful for those that have already lost their save file, but it's good to have something to refer to when the error hits. Until Sony patches the PS4 for this error, this is probably as close to a fix as we'll get.
Apr 04, 2014 | Washing Machines
Set aquapure not appearing on main menu
go into system setup you should see aquapure if set to 0 it will not show on screen also make sure the aquapure red 4 pin connector is plugged in so the PCB board and the PDA can see it
Oct 19, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Why does my webcam show a black screen?
Which version r u using? 8 or 9 beta?
1.for 9 beta:
*Can you see your cam clearly? I mean no black screen.
If your web-cam is having black screen, then you have to set it.
On main messenger screen:
click messenger
click connection
tick "connect directly to the internet"
click apply and ok.
Then open your cam and check if it working or not.
*Visit:
http://help.yahoo.com/l/us/yahoo/messeng...
2*Follow the steps below to change your camera source.
Click "Messenger"
Click "My Webcam.
Click "Messenger" again.
Select "Preferences."
Click "Webcam."
Click "Camera Source."
Click the pull-down menu and select the camera you want to use.
Click "OK."
*Best is to visit following link:
*Messenger 8 :
First, please check your connectivity settings within Yahoo! Messenger to make sure you're not connecting through a proxy server. Here's how:
Select " Yahoo! Messenger."
Select "Connection."
Select "No Proxies."
Click "OK."
Close Yahoo! Messenger completely and start the program again. This should eliminate the error message.
please visit these site
www.autodirectmarket.com , www.autoloanph.com to learn more
Apr 28, 2011 | Yahoo Messenger
How to reset a brother mcf-7420 printer?
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  2. From the main BRAdmin screen double click the appropriate printer.
  3. Enter the print server password (The default password is "access").
  4. Click the Control tab
  5. Click the Restore Factory Defaults button
  6. Click the OK button when you have read the warning message.
  7. The print server will then reset back to its default values.
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
  6. The print server will then reset back to its default values.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete. please rate it
Nov 29, 2010 | Brother MFC-7420 Printer
Write a program that requires a positive number containing a decimal point as input and then display the number of digits to the left of the decimal point and the number of digits to the right of the...
Here the code in C#:
public static double whole(double num)
double temp=0;
do { num--; temp++; } while (num > 0);
return (temp - 1);
static void Main(string[] args)
double num, temp;
int count1=0, count2=0;
num = double.Parse(Console.ReadLine());
if (num > 0)
temp = num;
do { temp /= 10; count1++; } while (temp > 1);
do { num *= 10; count2++; } while (num - 1 != whole(num));
Console.Write("Left=");
Console.WriteLine(count1);
Console.Write("Right=");
Console.WriteLine(count2);
else
Console.WriteLine("Positive only!");
You can translate in to other language.
But this works only for number less then 11 digit or it's very slow.
Rate me please, thanks.
Jul 09, 2009 | Microsoft Visual Studio 2005 Standard...
C code
try this Code
  1. #include<stdio.h>
  2. #include<conio.h>
  3. #include<alloc.h>
  4. void main()
  5. {
  6. int i, j,n,*p,check=1, blank, memspace, mem=0, rowdiff=1;
  7. printf("Enter the no. of rows to be printed :");
  8. scanf("%d",&n);
  9. blank=n-1;
  10. memspace=((n*(n+1))/2);
  11. p=(int*)malloc(sizeof(int)* memspace);
  12. for(i=0;i<n;i++)
  13. {
  14. printf("\n");
  15. for(j=0;j<blank;j++)
  16. printf(" ");
  17. for(j=0;j<check;j++)
  18. {
  19. if(j==0 || j==(check-1))
  20. p[mem]=1;
  21. else
  22. p[mem]=p[mem-rowdiff] + p[mem-rowdiff+1];
  23. printf("%d ",p[mem]);
  24. mem++;
  25. }
  26. for(j=0;j<blank;j++)
  27. printf(" ");
  28. blank--;
  29. check++;
  30. rowdiff++;
  31. }
  32. getch();
  33. }
#include<stdio.h>
void main()
int num,x,y,a[50][50];
clrscr();
fflush(stdin);
printf("Enter the number of rows: ");
scanf("%d",&num);
printf("\n\t\tPascal's Triangle of Order %d\n\n",num);
for(x=0;x<num;x++)
for(y=0;y<=x;y++)
if(x==y || y==0)
a[x][y]=1;
else
a[x][y]=a[x-1][y-1]+a[x-1][y];
printf("%4d",a[x][y]);
printf("\n\n");
getch();
Sep 20, 2008 | Computers & Internet
jasbo
jasbo
