Nothing
Take off the knob and see if the flat spot has been rounded out. If so, a new know should fix it. If not, unless you are comfortable taking apart the machine, it is time for service. If you are OK with disassembling the machine, open it up and look for the mechanism that should be turning when the know is turned. If there is an apparent broken part or loose connection, focus your effort on fixing that.
Testimonial: "thank you for the speedy reply. I assume you are referring to the knob which operates the stitch width? How do i remove it? I've tried tugging it off but it won't budge. p.s The needle can still be moved from right to left using the inner dial - but does not automatically go into zig-zagging as it should"
SOURCE: my zig zag is not working properly
no i have not received an answer to the problem from no one
neither anyone having a repair book on this machine, anyway the reason i cannot purchase a plan is because i dont have a crdit card.
SOURCE: I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
SOURCE: zig zag stitch & manual Husqvarna 5310
What numbr on the dial of the Husqvarna daisy is the zigzag??
SOURCE: missing stitches on zig zag with loose stitching underneath fabric
try changing the needle
adjust the top tension if nessary
