Question about Dryers
Hotpoint condenser dryer ctd 40g very noisy took black fan off and can hear something loose inside
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Something stuck in the blower housing? pull out off cabinet and u got a view
Posted on Dec 05, 2014
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
SOURCE: Hotpoint condenser dryer CDT00
how to connect the dryer belt to the motor is there is two pullys.
Posted on Jul 25, 2008
  • 250 Answers
SOURCE: my hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Posted on Jan 27, 2009
  • 51 Answers
SOURCE: hotpoint condenser dryer ctdoo
water pump at the back of the machine at the right hand bottom corner has either been blocked up with gunge which can me easily cleaned or the pump is not pumping, replace the pump
Posted on Feb 02, 2010
miket756
  • 2702 Answers
SOURCE: Not heating up
first thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Posted on Jul 12, 2010
Hotpoint condenser dryer noisy
hi if you push inside top at back of drum u will feel if lift if so yes u need bearing just ask for rear bearing for your model more than likely teardrop bearing
Nov 14, 2012 | Hotpoint Dryers
I have a GE Hotpoint side by side Model HSM25GF7A Serial # VL224529 It is making a loud squealing noise whenever it is running. It also seems to not be cooling as cold as it usually does? I took the...
The noise i suspect is coming from one of the 2 fans...if you hear the noise coming from inside the freezer it will be that fan thats noisy and if from down by the compressor that will the fan thats noisy. the part numbers for the fans are
fan in the freezer (evaprator fan) WR60X10185
fan by the compressor (condenser fan) WR60X10220
They could be purchased from your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Sep 07, 2011 | Hotpoint (HSM25IFTSA) Side by Side...
Flashing f 13 and leaking from bottom
Hello,this is an error with most of the Branded Washers like Hotpoint etc,
F13 indicates High Dryer Temperature.
Check the dryer motor runs OK and that the fan isn't hanging off. (You'll hear it if it is).
Check the connections to the dryer NTC (temperature sensor on top of dryer)
Check the condenser isn't blocked (under the fan motor, plastic unit going down the rear of the tub).
If all checks out OK, try changing the dryer NTC.
Thanks
Jun 10, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint ctd 40 wont heat up
Jan 27, 2009 | Hotpoint Dryers
Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Oct 25, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
Mar 30, 2008 | Dryers
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Noisy dryer
check to see if its level and let me know what kind of noise and age of drier
Nov 04, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
