Question about Cameras
I cannot keep a new battery from dying what should I do.
Three different types of battery
  • 3 Answers
Something is left on that is why battery draining must shut camera off. also if left in metal locker it will drain also if left out in car in cold will do the same
Posted on Nov 29, 2014
Battery keeps dying overnight
Hi Anonymous, you obviously have a short some where, either in the starter,ignition, or light ciruirt. you need to isolate which circuit is causing the short. Go to www.officialharleyparts.com and download a free wiring diagram for your year and model. Recharge your battery to 12.5 volts or better and with the key off start doing a series voltage drop tests between the battery and key wiring connections and components in one of the three circuits. What ever battery voltage you start with it should remain the same throught the entire circuit within half a volt. Use a test lite to further pin point suspect areas, make sure all connections are clean and tight, Once you have cleared one circuit move on to the next and repeat the process. Be patient and focused and you will find the problem. Good luck
Apr 18, 2014 | 2000 Harley Davidson FLHT Electra Glide...
When i pull out the power cord on my N150 plus the comp crashes,even though the battery is saying 100 per cent..any idea?
A lot of times this happens when the battery has gone bad and needs to be replaced. It might say 100%, but due to use (and sometimes just due to a faulty battery) the battery will charge less and less and eventually won't hold a charge at all. For example, when I first got my laptop a year and a half ago, I could get almost six hours out of a charge. Now I get almost twenty minutes. Unfortunately, I would say you need a battery. You can get one either from samsung (though you may have to call them, I couldn't find your battery on the site), Newegg.com, or ebay.com.
Some good tips for handling your new battery. First, if the computer's plugged in, remove the battery. Put it back in before you unplug it. This will prevent long-term wear on your battery. Secondly, it's good to regularly (I'd say yearly or so) let your computer "die" on battery (run it until the battery dies), then charge it completely THREE TIMES. This will "cycle" your battery. They say that with the newer batteries used nowadays this isn't an issue, because the new type of battery doesn't create the crystals like the older type does, but it can't hurt anything and I've noticed a difference when I do it.
I'm sorry about the bad news, but hopefully this will help!
Aug 22, 2011 | Samsung N150 (36725723009) Netbook
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
I just bought a new Nixon "The Banks" watch and the dial in the lower right hand corner, I believe it's suppose to be the second hand, won't work.
The Banks has three different batteries in it for each dial. The second hand battery died on it. I had the same problem and just went to a watch store and they replaced the battery for me.
Dec 28, 2010 | Nixon Banks Watch for Men
How to charge battery
The specs on this camera say that it has an external charger. Sometimes the usb cord will also charge the camera, but not all the time (depends on manufacturer). You will have to contact Polaroid, most likely, unless you can find a generic charger at Best Buy, etc.
Here is some information about the internal charger of the camera from redpowers.com:
The Lifespan of the Polaroid T737 Battery The life of a rechargeable battery for Polaroid T737 Digital Camera operating under normal conditions is generally between 500 to 800 charge-discharge cycles.
This translates into one and a half to three years of battery life for the average user. As the T737 battery begins to die, the user will notice a decline in the running time of the battery. When a battery that originally operated the device for two hours is only supplying the user with an hour's worth of use, it's time for a new Polaroid T737 replacement battery.
Is it Possible to Upgrade the Digital Camera Battery to a Newer Chemistry? NiCad, NiMH and Li-Ion are all fundamentally different from one another and cannot be substituted unless the Digital Camera has been pre-configured from the factory to accept more than one type of rechargeable battery technology. The difference between them stems from the fact that each type requires a different charging pattern to be properly recharged. Therefore, the Polaroid T737 Digital Camera internal charger must be properly configured to handle a given type of rechargeable battery.
They didn't explain how to configure, but it should be in the software menu of the camera.
I found batteries for this camera on google, but couldn't find a charger. Looks like if you have the right type of battery, the internal charger (through the usb port) will work.
Good luck, thanks for using FixYa, and hope this helps.
Aug 20, 2010 | Polaroid T737 Digital Camera
Alternator problem
1.You need to install a Fully charged battery, before you install a new alternator. Otherwise it will burn the alternator up.
2.I read what you typed about installing a new battery. Was the new battery fully charged, and was it installed before the new alternator?
No?
See number 1 above.
Sep 03, 2009 | 2004 Mazda 6
99 discovery/ dies while driving
sounds like the belt is loose. if it has a tensioner check and or replace it, if not tighten the belt. or the alternator tests ok but is actually not working at low rpm. or the battery is shorted. electricity is tricky
Dec 07, 2008 | 1999 Land Rover Discovery
Battery keeps dying got alternater fixed three times
i have a 2004 maxima and overnight my battery seems to drain out my car dont start i have to my battery is brand new and i leave no lights on is there a solution for this ???????
Jul 22, 2008 | 2004 Nissan Maxima
LG Chocolate
dont listen to the other guy you would not get three batteries wet unless your dumb... it is probably a cracked circuit board in your phone
Mar 10, 2008 | LG KG800 Cellular Phone
Don't know what this red thing is on the screen
There is an option for changing battery types in the menu. The accs that came with my camera where very good Lithium-Mh type. If replaced with ordinary Alkaline non-rechargable, you have to adjust battery settings, probably also if you got the very expensive Lithium-Ion batterys. The thig is that these three types has different voltages; 1.2, 1.5 and 3.2 (I think) respectivly.
Wrong settings could perhaps cause this your problem.
Dec 28, 2007 | Nikon Coolpix 5600 Digital Camera
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
