Question about Air Tools & Compressors
Paslode Im350 fan keeps running and fires nails on contact with timber without pressing trigger?
  • 3 Answers
It sounds like the "spring" at the back of the gun has gotten bent pressing down on the rear activation button that turns the fan on. This spring has a loop at one end and a roller at the other, remove it and slightly bend the it down. Not much
Posted on Dec 08, 2014
Paslode im350 fires every time,but nails dont come out
Unless you have the wrong nails or a problem with the feeder and/or feeder spring it is probably dirty and the driver is hanging up on the cylinder. These tools need to be cleaned and lubed after using them for some time. If you look on Paslode's website there is a manual that explains how to do it. There are also videos on YouTube that show this. It is somewhat complicated and the tool has to be disassembled quite a bit. If you don't feel comfortable doing this work then you may want to want a servicing dealer that repairs these tools. There is a rubber o-ring on the head and a filter on the top that should be replaced too. Here is a link to the cleaning guide.
Paslode IMCT cleaning guide
Aug 26, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350/90ct green light goes red when applied to surface and wont fire
Unplug. Check that you don't have a nail jammed in the end of it.
Apr 03, 2012 | RTO Air Tools & Compressors
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
Jun 23, 2011 | Air Tools & Compressors
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350 will only now wrk properly when on a flat surface i cannot fire in at an angle without it mis-fireing
Make sure the nails are inserted so that the follower maintains pressure on the strip of nails. Also, your pressure on the whole gun at an angle is probably not as great as on the flat---could lead to misfiring
Mar 02, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im350 piston will not return
It sounds as if the piston o ring is worn. Does the piston drop if you just give it a slight bump with no nails in the magazine, if so that is the problem and would need replaced. Let me know otherwise and I will dig deeper
Jan 24, 2009 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Air Tools & Compressors Logo
97 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
