Question about Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung LN T4061f flat screen that has developed horizontal lines that happens on every input as well as effecting the menu. i tried adjusting all the settings and it seems to get a little be
Updated the firmware and adjusted all settings back and forth to see if it help
    Top Expert:
  • Samsung Master
  • 74,243 Answers
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 29, 2014
  • 192 Answers
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Posted on Jun 03, 2007
  • 146 Answers
SOURCE: Green color on Samsung ln-t4042
If the whole screen has this tint problem, there is nothing you can do. It must be repaired. You will need to take it in for service.
Posted on Mar 15, 2008
  • 280 Answers
SOURCE: Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
Posted on Jul 03, 2008
  • 5 Answers
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Posted on Jul 15, 2008
SOURCE: Firmware update caused static on the display
See previous comment
Posted on Nov 19, 2008
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
LN-T4061F turns on black screen sound is there and no menu appears
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backklight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Feb 27, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
My samsung l n-t4061f/ln 40 inch tv has rainbow dots on the screen and when i turn it on it has vertical pinks stripes on the screen.need your help
The problem was solve my power chip or piece burnout.So iam taking it to the shop to have it fix.Thanks for all your help
Nov 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
I have a LN-T4061F Samsung LCD, I'm seeing vertical bars across the screen
most of the time this is the ctrl board its like a graphic card tells the screen what to show,but the cable from that goes to main board sometimes this is the cause of lines/open it get no of control board it has a 30 pin thin lead going to main board and google it easy to replace plug n play
Nov 10, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Screen shows several horizontal and vertical lines.
this can be in your video cable or LCD Connector issue. but most problem is in the flex cable of LCD. some other cases cannot be fix and replace new LCD Screen.
Aug 14, 2009 | Samsung HP-S4253 Television
LN-T4061f samsung lcd no backlight, no sound, no picture
Replacing the capacitors would be a good start. Replace all the ones with the same capacitance and voltage rating even if they do not look bulge.
Let me know if you require further assistance.
Mar 14, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-T4061F 40 in. LCD HDTV Logo
102 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
