Question about Lands Phones
Replacement batteries do not seem to be charging. Have checked they are the right sort of batteries. What am I doing wrong!?
Replaced batteries with supposedly correct ones. Handset had been on base for well over 24 hrs but still no display
    Master:
  • 623 Answers
The assumption is you replaced the batteries because you thought they were bad. It's highly possible the charger of your base is dead. If you have a voltmeter see if there's voltage (10% or more greater than the rated voltage of the battery). If not, it's the charger that's dead, not the batteries.
Posted on Nov 29, 2014
Testimonial: "Thank you .never even thought about that possibility!"
SOURCE: handset
Presume you are talking about the extra handset. Try placing the extra handset in the "main" base for 5 seconds.
Posted on Aug 28, 2007
  • 146 Answers
SOURCE: Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Posted on Jan 16, 2008
SOURCE: ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Posted on Apr 14, 2008
SOURCE: My handset displays "New Voice Mail" and the base displays 00.
This is the problem, thebase charge light flashes continuously,It says that I have a new voise mail and the the base says (00)
Posted on Mar 05, 2009
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
Have an 07 f350 Ford pick up 6.0L power stroke .batterys replaced . Alternator replaced . Dash battery light still stays on no charge .soure voltage gd to alternator ,and plug . Reads gd voltage to si
I would try the regulator, there is a few tests to see if the alternator is charging, use a multi meter and check the b post on the alternator and earth and see what voltage it is producing, check all those sort of things and you will find the problem, make sure the battery terminals are very clean or they won't accept charge as well, hope this helps
Dec 28, 2014 | Ford Cars & Trucks
I have a riding lawn mower the wiring shorted out now the starter turns the wrong way
If you replaced the battery make sure the post polarities are the same as those of the replaced one. These lawnmower batteries, of the same physical size, are available 2 ways. one has the positive terminal on the left side and the negative on the right side. The other battery is exactly opposite. Interchanging them often requires you to buy longer battery cable for one side, while the other cable becomes excessively long. In most cases it's easier and cheaper to get the original configured battery as a replacement.
Check your connections if you've already done some wiring repairs. I can think of no other reason for an original starter to turn backward unless the wiring from the battery is reversed or the battery is the wrong configuration as above. Good luck.
May 03, 2014 | Washing Machines
Charging
The replacement battery may be no good
May 31, 2013 | Dell Latitude XT Laptop
Why won't my Garmin Nuvi 780 charge?
A couple part answer here. The USB pin out for the Garmin is strange. If it goes into PC mode, then the cable is got the wrong pin out for the unit. Try different cables until one works.
If you can get a full charge on the unit and the battery does not provide at least an hour + of battery use, then the battery needs to be replaced. Amazon sells replacement battery kits with instructions. You just have to make sure you order the right one.
Sep 18, 2017 | Garmin nuvi 780 GPS
I already replaced my charger once. This is the second time it just wont charge my laptop and it hasn't even been a year since I replaced the last one. What is wrong?
guess the problem is with your laptop battery....chargers normaly dont crack soon.....
charging the battery....is not OK
to sort out the issue
do this...
1 remove the battery from the battery bay....(hope u know how to do that)
2 now connect the adaptor and check if the notebook works....(without the battery in the bay)
3 now remove the adpator and install the battery...check if it now works with just the battery....
4 now connect the adpator to notrbook with the battery in it's bay...start the notebook.....and let it work for some 3 - 5 hrs
5 remove the adaptor...check if the battery immediatly takes over...if not then battery is the issue
Feb 17, 2011 | Compaq Presario CQ60215DX Laptop Charger...
My 1998 ford mustang v6 3.8l .. is hard to start for first start of day i have to keep cycling the key and cranking on it , seems like fuel but is not i replaced fuel pump , fuel filter, fuel pressure...
So what you saying is it's hard to start cold right? Something in computer system not allowing excess fuel to injectors when cold. Probably sensor Get auto electrician to sort it out otherwise you end up replacing things that there is nothing wrong with They got the right gear
Jan 27, 2010 | 1998 Ford Mustang
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
Jan 10, 2010 | Acer Aspire 5735 Notebook
Charging light come on after alternator replaced
No fusible link, make sure the wires connected to the alternator are making good contact. If you installed a rebuilt alternator, it could be defective. Also check the voltage regulator
Aug 31, 2009 | 2004 Mazda 6
Battery Installation
Go back and check your grounds, they are known to vibrate loose.
Jun 02, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Channel Searching message, but phone is right next to unit
If your phone worked fine and this problem just started happening and seems to be getting worse, I would change the battery, even if the charge light indicates that the battery is charging and you "think" the battery is charged.
Most of these weird problems that start occurring in a phone that always worked fine are caused by the battery goinf dead. You can buy a replacement battery on ebay for like $6-$7 with shipping for most models of cordless phones. I sort of rehab cordless phones that I get at yard sales and at goodwills and sell them on ebay. Out of 50 or 60 so far, I have never found a broken one. I have found, however, plenty of phones that initially display all sorts of weird symptoms which are ALWAYS -- and i mean always -- fixed by a new battery. Good luck.
Apr 07, 2009 | Sony Lands Phones
Lands Phones Logo
79 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
