Hope you guys deal with world space recievers too my antenna for JVC world space digital receiver ain't working can you guys help me out or even sell me a new piece?
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
What i do my world space recever jvc
The JVC space receiver is an excellent unit which performs absolutely fantastic. What is wrong with your system? refer to your manual for ntroubleshooting tips
Jan 02, 2011 | JVC Audio Players & Recorders
I have a message that says no signal o signal
your tv is working but your antenna or recieving device is not sending a strong signal to your set, try using a hd antenna or a dvd device maybe a cable reciever or similar, to see if your able to see a picture but usually its a signal problem not something wrong with your set.. hope this helps
Jun 03, 2010 | JVC LT-42X788 42 in. LCD HDTV
Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Jun 16, 2009 | JVC AV-27230 27" TV
It sux!! BLACK screen when we can see the picture
Try another scart cable if this dose not work take it back "no return"deal or not.The player was sold to you as a dvd player not a paper weight.
Hope this helps.
CABLE GUY.
Apr 18, 2009 | Denon AVR-3802 Receiver
Digital audio not recieving signal from dvd player
I have the same problem on the same receiver. I split my cable and plugged one side directly into the system, and the other I used a 300/70 ohme converter to plug into the fm antenna side. This helped to get stereo on local stations. I think I am going to have ot go for an outdoor antenna to get anything more.
May 31, 2008 | Accurian AVR-5048 Receiver
Dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Feb 03, 2008 | JVC RX-7030V Receiver
JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Dec 03, 2006 | JVC RX-618V Receiver
 Grubhead
Grubhead
