Westinghouse ld-2480 powers up with red light however will not turn on to blue light
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Nov 29, 2014
    Master:
  • 149 Answers
Apparently, the unit is not able to power on. Outside of a possible issue with the remote controller's interaction, either the television unit is not receiving enough electrical current to so do (to power on), or it has an issue at the circuit board level. If it is not receiving enough electrical current, then the power adapter could be at fault.
The manufacturer makes no mention of an energy conservation switch on this unit other than the power/standby button on the television unit. Ascertain that you have the appropriate remote for this television unit. (The button locations later mentioned refer only to the original remote controller supplied by the manufacturer.) Clear obstructions from the front of the television so that nothing hinders the remote controller's pathway to the television unit's receiver. Try powering on the television unit by using the remote controller (USING THE RED BUTTON AT THE TOP END OF THE REMOTE CONTROLLER-NOT THE "TV" SOURCE BUTTON ON THE FOURTH ROW OF BUTTONS). Then try powering on the television unit by pressing the aforementioned power/standby button directly on the television unit.
If the remote controller does not power the television unit on but the unit's direct button does, then the remote controller apparently has a problem in either its battery power or some aspect of its function (the contact(s) on the keypad could be defective or gaining resistance). Test for the resistance issue by continuing to depress the remote controller's power button until the television responds or for up to ten seconds (whichever occurs first). If the remote controller does not initially power on the television unit until after a delay during this remote controller keypad resistance test then the remote controller should be replaced. If the remote controller only turns the television unit on when closer than the usual distance from which it is normally used or not at all, then try again after replacing its batteries & make sure that the battery contacts are clear of any obstruction (such as debris, plastic, an object, or corrosion). If the remote controller still does not power on this television unit (but the unit's direct button does) then the remote controller could be faulty.
The power adapter's design specifications for electrical current are listed either on the power adapter or on the back of the television unit (either near the power inlet or wherever the majority of model information is presented). The power adapter's specifications will have a symbol arrangement with a - or a + on the outside of a C with the opposite - or + on the inside of that C. The manufacturer uses the C to represent the power connector (the end that plugs into the television unit) in terms of which polarity of electricity is set to flow internally & which polarity of electricity is set to flow externally to the round pole of the power connector. For television units sold in the United States of America, the - represents negative current, & the + represents positive (hot) current; & this AC/DC power adapter transforms the building's/household's alternating current (AC) into direct current (DC).
WARNING: ALWAYS REFER TO SAFETY GUIDELINES WHEN HANDLING ELECTRICITY OR ELECTRICAL DEVICES (http://www.electricalsafety.org/). FIRST, REFER TO THE MULTIMETER'S INSTRUCTIONS TO TEST YOUR MULTIMETER! (A multimeter is separate device used to determine the presence & amounts of varying electricity conditions. It is a separate tool that should be in your own tool kit.) Using a multimeter, a person could test for continuity & for the DESIGN-SPECIFIED levels of amperage & of voltage.
A power issue could exist in any one or combination of areas including (but not limited to) the power outlet, any indirect power source through which the television unit is perhaps connected (such as a surge suppressor/protector, a power tap device, or an unlimited power supply (UPS) device), the power adapter &/or an internal television unit component/condition. If the power adapter fails at this power outlet, then take it to a different room & test it, again. If it passes at the initial location, then the television should be serviced by a professional. If it fails at either location but not at both, then the power outlet in which it failed would appear to have a problem * (* = not necessarily the television unit's only problem). If it fails while plugged into an indirect power source device, then try again after resetting the power to that device. If resetting the indirect power source device proves unsuccessful, then temporarily bypass that device by plugging the power adapter directly into the power outlet. The indirect source of electricity could be defective *. If the power adapter fails in every test, then the power adapter is at fault & should be replaced *.
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: My westinghouse ld-3255vx tv will
The standby power supply is working but the rest of the set is inshutdown mode, it can be due to bad power supply (bad caps, etc.), backlights inverter board, main board. You will have to do in-depth troubleshooting and please read my guide to understand how thw LCD TV works.
It will need parts for sure.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 17, 2011
  • 9771 Answers
SOURCE: Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Posted on Jan 09, 2014
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
How do i find the power supply
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 30, 2015 | Westinghouse Televison & Video
Westinghouse LD 2480 wont power up
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 30, 2015 | Westinghouse 24" Class 1080p 60hz LED LCD...
I have a 24 inch White Westinghouse TV model #ld-2480 when I turn it on the blue light comes on then it goes out by itself
Main board fault. Shorted component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/
Aug 03, 2014 | Televison & Video
Westington tv wont turn on
My tv is a Westinghouse**** Sometimes i move the tv slightly and the cord partially comes out at the side and i just push it in all the way and all is ok
Nov 30, 2013 | Westinghouse 46" Class LED-LCD 1080p 120Hz...
Power adapter
http://www.ebay.com/itm/AC-Adapter-4-Westinghouse-LD-2480-24-LED-HDTV-TV-Charger-Power-Supply-Cord-PSU-/261042434846?pt=US_Monitor_Power_Supplies&hash=item3cc757731e
Aug 13, 2012 | Televison & Video
Code for Westinghouse LD 2480 LED TV
Look at the back of your remote... It should give you a simple fix... WORKED FOR ME!!!
Jan 18, 2012 | Westinghouse Televison & Video
Televison & Video Logo
307 people viewed this question
Top Televison & Video Experts
Electro Med Services...
