Question about Garden
Sears Craftsmen Poulan leaf blower model 358.797770 How do I gain access to starter pulley assembly and spring?
  • 1,169 Answers
Not an easy job to get to on this Weedeater made blower; have plenty of work space and a very good memory. It requires removing blower end which you will end up disassembling the whole casing.
When re-assembling don't over torque the fan mounting nut as it will cause the flywheel to bind.
Here is a link to the parts diagram at Sears Direct.
http www searspartsdirect com Craftsman Leaf blower Parts Model 358797770...
Posted on Nov 29, 2014
Rewind pull cord poulan pro snowblower pulled cord first time and will not rewind back
If you are a fix it kind of guy you can remove the starter assembly and check the recoil spring.
Dec 19, 2013 | Poulan Garden
Oil leak on poulan snow lower
follow this steps and fix it. God bless you
  • Remove the hex bolts holding the plastic leaf blower housing in place with your hex wrench. You may wish to cut the cord with your scissors and loosen the bolt or screw securing the rope assembly with your hex wrench or screwdriver.
  • 2 Remove the spring assembly carefully. Do not remove the spring, only remove the assembly.
  • 3 Remove the old cord from the leaf blower pull cord assembly by gently pulling it away from the assembly with your hands. Notice the direction the pull cord is wound, as this becomes important in the next step.
  • 4 Wind the new pull cord in the same direction you removed it in Step 3. Make sure the inner end of the pull cord secures in the faster or slot provided on the pull cord assembly. This varies depending on the leaf blower manufacturer.
  • 5 Replace the pull cord pulley and place over the spring. This is the white plastic spool.
  • 6 Rotate the pull cord assembly two or three times in the same direction the cord pulls wearing safety goggles and work gloves. Reinsert the center screw by screwing it in place with your screwdriver; this holds the pulley assembly together
  • 7 Insert the leaf blowers cord end into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new pull cord; this prevents the handle from being pulled off the pull cord while you start the leaf blower.
  • 8 Place the pull cord assembly back onto your leaf blower in its designated area and secure by refastening the four hex nuts with your hex wrench.
  • 9 Replace the housing cover of the leaf blower and refasten the hex nuts with your hex wrench. You removed the housing cover in Step 1.
Nov 24, 2013 | Garden
I acquired a Craftsman Gas Blower model 358.794765 with the Sim-Pul starting system. The pulley was jammed with about 6 inches of rope hanging out. I took it apart and did not find anything broken. The...
Look at the housing where the spring should lay. There is a small shaped bend on the housing. This is where the bend of the spring should sit. Remove any tape on the spring before placing in unit. DANGER: Be careful not to move spring too much after removing and tape. It might unwind and fly into your face.
Sep 04, 2013 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
How to repair spring starter on FL1500LE
The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
Nov 24, 2009 | Poulan Featherlite Gas Blower, with Low...
Craftsman 316794990 leaf blower. I have a problem
Lakeviewpower dot com here is a link to my website. Call me on price and avilibility. Part number mc 9228 320602. Mtd model number 41ar322g799 1 972 475 9946
Nov 21, 2009 | Craftsman Blower Attachment
Broken pull starter rope
remove pulley that rope goes on, wind it with new rope, wrap it till it is full, then feed rope thru hole in housing, put pulley back in place, put rope thru pull handle, pull thru till you feel spring catch tie a knot and that should do it......be careful when removing pulley not to dislodge recoil spring
Oct 22, 2009 | Garden
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
How do you relace the recoil spring in poulan weed eater lt1500le
Hello dan_montecar:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
This is a Basic File and your Unit May be Slightly Different.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Poulan 12a Elec Blower/Vacuum
Recoil spring broken
you need to supply the brand and model of the blower so i can look it up
Feb 13, 2009 | Poulan 12a Elec Blower/Vacuum
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
