Question about Dyna-Glo Heating & Cooling
I bought a new heater last week , and it was working fine , but today morning when i turn it on the gas start leaking and just the gas fumes were comin out , what problem it could be.
    Sergeant:
    Champion:
  • 214 Answers
Sounds like the ignition is not working.
Posted on Nov 30, 2014
  • 29 Answers
SOURCE: the gas was turned off last week and now the
re light the pilot
Posted on Jun 21, 2009
SOURCE: Gas heater smells like kerosene and stings the eyes,
this probably occured after you were vanishing timberin your house and has since stopped
Posted on Aug 01, 2009
  • 53 Answers
SOURCE: rennai gas unflued heater kerosene fumes
Have it checked properly - sometimes the reg won't open fully, but the heater will still run, but with improper combustion resulting in a funny smell.
Posted on Aug 16, 2009
  • 1341 Answers
SOURCE: smelling gas
You must have a leak somewhere..Do not use this heater as it could be very dangerous.
Posted on Dec 12, 2009
  • 224 Answers
SOURCE: My reddy heater 170t is
Several things come to mind here. Fuel type, fuel delivery, and dirty filters. Make sure to use the K1 keroesene it burns so much cleaner and less fumes. Contaminated fuel, old and possible water from condensation after being stored all summer. Remove the top cover of your heater and fire it up look at the fuel coming out of the nozzle, it should be a very fine mist no heavy droplets. If heavy droplets nozzle could need a cleaning, they say that you should not clean these because you can damage them. I say remove the nozzle, and carefully clean with carb cleaner, q-tips, and tooth pick. Clean the screen behind the nozzle as well they like to corrode. While inside take windex and a soft terry cloth rag and clean the flame sensor inspect fuel lines for holes, dry rot, or cracking put the top half back together. Remove the side panel trace the fuel line to the filter and tank. Remove the filter and I find that a compressor and blow gun work best to clean by blowing air backwards thru the filter, instantly clear. reassemble fuel lines. On the rear of the heater is a foam intake filter remove it and wash it out dry real good and put it back together. Now try the heater and you should be good to go, if not it may be pressure related and you may need to turn the pump up or down slightly to get a better air fuel mixture. These are common yearly preventative maintenance I pull on all of my heaters and I have four of them for in my warehouse. Take your time and good luck.
Posted on Dec 21, 2010
Working on furnace. igniter not working even after replacing.
Check flame sensor , check hoses to pressure switch not split etc
Oct 24, 2015 | Goodman Heating & Cooling
Why does my blue flame ventless propane heater go out for no reason?
Did the gas man use a manometer when the gas pressure was adjusted up? The three basic types are 1. round needle guage capable of measuring approximately 30" water column pressure, 2. U-tube manometer filled with a clear or red glycol, and 3. digital guage.
It sounds like the gas pressure is a few inches water column too high which could cause the pilot flame to actually lift off the thermocouple tip causing flame failure after the gas valve opens. More is not necessarily better when it comes to gas pressure. Normal propane manifold pressure is around 10.5" w.c. with maximum inlet pressure of 14" w.c. This pressure can be accurately measured with one of the above listed manometers by tapping into the manifold downstream of the gas valve or in the pressure tap on the downstream side of the gas valve. Most normal 100% redundant gas controls have an individual pilot adjusting screw in the valve itself for adjusting the pilot size and pressure independent of manifold pressure.
Nov 22, 2014 | World Heating & Cooling
I wondering if my Pelonis gas-filled heater is emitting dangerous fume causing me to feel depressed... do you have the phone number of the company?
Have you tried not using the heater for several days to a week, to see if your depressive state improves? That would be the litmus test involving the heater, wouldn't it?
Never the less, their phone # is 1-866-876-4332
Feb 16, 2011 | Pelonis HO0221 Electric Radiator Heater
I have a 2001 civic ex manual trans with 67,000
Sounds like the clutch is worn or the throw out bearing. You will need to have both checked. As far as the gas fumes go, check your air filter to make sure it doesn't need to be changed, if your fuel injected check to make sure you don't have leaks around your injectors. Finally check the gas fume collector for damage or bad vaum lines.
Jan 25, 2010 | 2001 Honda Civic
Toyota Corolla 2008 with 9000 miles occassional gas fumes inside car starting about a month after I bought the car..can happen a few times in a week then not for a few months. Usually starts after I am...
they need to check under your back seat and see if the seal is still working your gas tank sending unit is under your back seat .toyota needs to do this for you
Jan 14, 2010 | Toyota Corolla Cars & Trucks
Smelling gas
Dec 12, 2009 | Reddy 30m Btu natural Gas Heater
Vapors coming through the vent w/AC & heater on - 96 VW Golf
Bad heater core. What is happening is when you turn on the air you are getting fumes from the heat of the engine and the heater core leaking causing you to get a smell and also fumes. I would suggest that you take it to the dealership or a mechanic and have the problem fixed ASAP due to the health issue
May 27, 2009 | 2003 Lincoln Navigator
Low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
May 10, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Headlights
check under the hood of the car instead of within the chasis for the headlight fuses.
Dec 09, 2008 | 1993 Buick LeSabre
Heating & Cooling Logo
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
