What id the difference between a SNP and a DDR2?
Someone is looking for a DDR2 and I have a SNP J)203C/1G
    Sergeant:
  • 269 Answers
DDR2 memory is referred to as DDR2 SDRAM. The memory module won't actually normally say DDR2 and is referenced by manufacturer part numbers and the particular physical features differing it from DDR and DDR3 memory. Your reference number appears to be incomplete to provide a specific answer to what type of memory you actually have other than perhaps referencing a 1 GB module. Enter your correct part number in a Google search for specific details.
http://upload.wikimedia.org/wikipedia/commons/1/1b/Desktop_DDR_Memory_Comparison.svg
Posted on Nov 29, 2014
3 Suggested Answers
SOURCE: memory upgrade from ddr 256mb to ddr2 1g
mhtml:http://www.foxconnchannel.com/upload/Compatibility/200703291139540676P4M800P7MA-MEM-070212.mht
Posted on Apr 15, 2008
SOURCE: I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
Posted on May 19, 2012
Testimonial: "thanxxxx but i did it"
May 18, 2012 | Computers & Internet
Dell Laptop Inspiron 2650 will memory module SNP JO203C/1G work with my computer
no it wont fit. maximum memory for your computer is 512 ram and you need SODIMM. also its a very old computer you have and memory to your computer could be very expensive or hard to get.
so I suggest you buy a new computer
Mar 08, 2012 | Dell Inspiron 2650 Notebook
Good day. I just would like to inquire if the Palit 8400GS 512MB/DDR2 video card that I recently purchased is really compatible with the Elite Group P4M900T-M2 (REV:1.0) motherboard. I also upgraded...
Yes, Palit 8400GS 512Mb/DDR2 video card is compatible. It was a great decision you've made that is to upgrade the RAM (memory) as well from 1Gb to 1.5Gb. Your P4M900T-M Motherboard is capable of handling upto 4Gb. You might want to consider to upgrade its memory to 2Gb, 3Gb, or to its full capacity, 4Gb. Definitely, it will greatly affect your computer's performance as you are distributing its resources (video, motherboard, memory, etc) to perform individually as it was designed for.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Mar 29, 2011 | EliteGroup P4M900T-M (V1.0) Motherboard
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Will pny pc2-5300 work with a emachines t5082
Ships with
512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB
2 DDR2 Slots (Total) | 1 DDR2 Slot (Available)
recommend
512MB PC2-4200 M-533D-512BD10
Aug 24, 2010 | E-Machines T5082 PC Desktop
My dell power light was off one morn,but my
Seems to be a Memory or a Motherboard failure. Make sure the memory you upgraded are the ones which are compatible to the system.
The compatible memory modules for your system are:
DIMM, 128MB, DDR2, 400M, 16X64, 8, 240pins
DIMM, 256MB, DDR2, 400M, 32X64, 8, 240pins
DIMM, 512MB, DDR2, 400M, 64X64, 8, 240pins
DIMM, 1G, DDR2, 400M, 128X64, 8, 240pins
The power light not turning on can be the Front bezel issue and not a system/motherboard failure. Please revert for any more issues.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
Gateway memory problems mx3225, I can not upgrade from 256 m to 1G have tried to different modules same result black screen
1GB RAM for Gateway MX3225 (DDR2) Memory 1GB 533MHz DDR2-533 , PC2-4200, 200p SODIMM, 1.8v, CL=4, 128Megx64 - Kingston Brand works.
Jul 19, 2009 | Computers & Internet
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Memory upgrade from ddr 256mb to ddr2 1g
there is a jumper setting to slect which type of memory you want to use, check your manual for details on how to change it
1> enusre the rams are in correctly
2>ensure your main board supports the amount of memory and the speed of the memory
3> verify jumper select to correct memory type is set correctly
if the main board aint compatable with the memory you brought that will cause the same problem
Jan 02, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
