Question about Kohler Home
I replaced a Kohler temperature balancer (GP522520). After that the water keeps running - can't shut off. Suspect an issue with the mixer cap in front of the balancer (GP77886). What could I have done
I took out & reinstalled the balancer (GP522520) & mixer cap GP77886) several times. All seals are in tact. The mixer cap did pop open & I had to reposition the springs inside the cap
Cyril J
  • 45 Answers
SOURCE: refridgerator door
a lot of the sub-zero doors are good and heavy duty, but the plastic shim under the hinge wears and can drag when you go to close door, usually a simply repair to find a washer for the door hinge.
Posted on May 16, 2008
  • 49 Answers
SOURCE: Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Posted on Jan 23, 2009
mmoorree
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
SOURCE: Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Posted on Oct 21, 2009
SOURCE: the kohler steam unit keeps shutting down prematurely
I've been struggling with this exact error for the past week and fixed it last night. The Error 5 message was misleading in my case and actually was caused by the steam outlet inside the shower and, even after replacing the entire unit and getting the same error, i fixed it in two seconds. Since this was one of the posting i encountered during my frantic searches, i thought i would come back and share my blog posting on this error and my fix:
http://fixitben.blogspot.com/2010/01/kohler-k-1658-240v-steam-generator-and.html
Posted on Jan 05, 2010
No hot water in shower. Sometimes runs hot then goes cold or runs cold. I have less than 2 year old Kohler Faucet K-T10448-4-CP. I replaced the pressure balance valve unit. No luck. I changed the hot...
Refer to the manufacturer's recommendations for back-flushing/descaling to flush out mineral deposits and build-up in the heat exchanger. You can check to see if this is a problem by comparing the full cold water flow with full hot water flow at the faucet. If the hot water flow is significantly slower than the cold then the heat exchanger is likely clogged with deposits and will not transfer heat sufficiently. If the flow is good then the heating element(s) maybe defective.
Feb 17, 2015 | Kohler Plumbing
Why does my Kohler Champlain keeps running slowly
The mechanism controlling the water is worn. Replace it if you can't get a kit to replace the worn parts.
Jul 20, 2014 | Kohler Home
Cold water going through to hot side
Replace pressure balancing spindle part number 500520 from Kohler, if you purchased part Kohler warranty may cover issue, Kohler Customer Service 800-456-4537
Apr 09, 2014 | Kohler K-2971-KS-NA Hiflow Rite-Temp Valve...
My water pressure drops when I turn temperature to hot. And the temperature changes throughout the shower. What could casue this?
Hi! The problem may be the pressure balance cartridge needs replacing. I have seen trash (small rocks -a piece solder-Teflon tape-rust from pipes) cause this problem, but you will have to remove the the cartridge to find out.
May 21, 2011 | Kohler K-T14420-3-SN Polished Nickel...
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
Bosch 2400E-NG output temp fluctuates
This is a great heater. It is however crucial that it be installed to every detail of the manual. If there is trouble send pictures to Bosch tankless you can call 1-800-283-3787 ask for Bosch Tech support or go to boschhotwater.com click find a contractor and call the closest Bosch Service Provider most will travel.
Mar 04, 2010 | Bosch AquaStar 2400ES-NG
Water not hot at the Symmons Safety Mix valve. Had plenty of hot water before I installed a new hot water heater. Now, it's not as hot. I turned up the temperature to about 130 degrees. Sometimes it is...
There might have been some sediment that came thru the water line after changing the water heater and got into the mixer valve. You may need to shut off the water and clean out the mixer valve assembly.
Oct 27, 2009 | RTO Symmons Deluxe Temptrol pressure...
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Home Logo
42 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
