Question about Dell Computers & Internet
Driver where Windows is, is locked. How do I unlock it?
    New Friend:
  • 30 Answers
If windows has a passsword lock there is software that will unlock it
youtube is a good place to start looking for links.
Posted on Nov 29, 2014
I put the key in the lock and unlock the car and the windows come down its a skoda fabia 2010.
Hi Ian.
Your car is probably have the windows roll feature.
In other words, using the key in the driver door, lock the car and hold the key in lock position, the windows should close all the way up unless you release the key.
Same thing if you unlock and hold, the windows should roll down.
Let me know when you try it.
Good luck
Sep 17, 2015 | Skoda Cars & Trucks
What causes a malfunction in power locks?
The power door locks are controlled by the BCM -body control module ! The door lock switch is an input to the BCM .
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
First thing to do would be check power an ground circuits at the BCM ! Do you have any other systems not working -power windows etc...
The DR/LCK fuse supplies battery positive voltage to the I/P fuse block for the door lock system. The body control module (BCM) supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position or unlock position, the reference voltage is taken directly to ground and the BCM detects the voltage drop on the signal circuit.
Should have BCM checked for stored DTC'S - diagnostic trouble codes !
Ignition ON, observe the scan tool Driver Door Lock Sw, Psgr Door Lock Sw, Driver Door Unlock Sw and Psgr Door Unlock Sw parameters while using the driver and passenger door lock switches. The parameters should change between Active and Inactive.
If the values does not change between the commanded states, refer to Door Lock Switch Malfunction.
Command the driver door and passenger door lock actuators to LOCK and UNLOCK with the scan tool, the doors should LOCK and UNLOCK when changing between commanded states.
If a door lock actuator does not perform the LOCK and UNLOCK functions, refer to Door Lock Malfunction
DTC B3130 00: All Door Unlock Circuit
DTC B3135 00: All Door Lock Circuit
Aug 09, 2015 | 2010 Chevrolet Impala
Power windows stopped working in my 01 Denali
ON THE DRIVER SIDE BELOW the window is a child safety lock for the other windows unlock it
Aug 06, 2014 | Cars & Trucks
2005 Chevrolet Tahoe Power Windows and Power Locks not working.
The power windows an power locks are controlled by a module , DDM - driver door module . As far as the locks locking when you put the vehicle into reverse an unlocking when you put the vehicle into park , that's how there are suppose to work , automatic lock an unlock feature . When you put the vehicle into any gear from park the locks should lock . Did she hit window lockout function ?
The power door lock system consists of the following components:
• The driver door module (DDM)
• The passenger door module (PDM)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock switch
• The door lock relay
• The door unlock relay
• The liftgate lock relay--utility vehicles with liftgate only
• The reversible door lock actuators in each of the doors and liftgate
• LOCKS 20A fuse (rear lock/unlock relay supply voltage)
• ECC 10A fuse (liftgate lock relay supply voltage .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Driver, Passenger and Cargo Door Lock System Operation
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
• The DDM (driver door lock actuator).
• The PDM (passenger front door lock actuator).
• The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
Mar 16, 2017 | 2005 Chevrolet Tahoe
How to unlock
Follow the method below to unlock windows password
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Reset
Details: http://www.windowspasswordreset.net/article/article.html
May 15, 2012 | Toshiba Computers & Internet
@att.netmy window will not go up on driverer side could it be a fuse
Had similar problem with my 2004 Kia Optima. I could control the driver window and door locks with the panel but the other windows and door locks would only work one way (open or close but not both). Had the switch panel on the driver's door replaced. Windows all worked after that but still had issue with door locks ... I can lock them all, just can't unlock them from the driver's door. They have to be unlocked from each individual door. I guess can live with it. FYI ... the switch panel for the driver's door was $250 from a Kia dealer so you might want to check salvage yards for it.
Sep 14, 2011 | 2002 Kia Sportage
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
Jul 10, 2010 | 2000 Chevrolet Blazer
Computers & Internet Logo
Alun Cox
