Question about Electrolux Genuine Frigidaire Refrigerator Door Handle 218428101
A loose door handle on frigidaire refigerator
Pulled up on handle to remove handle and tighten screw
    Sergeant:
    Champion:
  • 282 Answers
There are usually some hex head screws on the upper and lower sides of the handles make sure they are tight.
Posted on Nov 29, 2014
Door handle has come loose
I think you can just use a quick dry super adhesive glue to hold the handle in place.
Jul 28, 2008 | Frigidaire 14.1 cu. ft. / 399 liter...
The handle is loose, how do we take the covers off so we can tighten the screws?
I had this same problem with one of my refrigerators. Most refrigerators that do not have a screw you can access will clip on to the door. Be careful because this may not be one you can do, but you should at least try. All I did was pull up firmly on the handle and it shifted up and the mounting hardware for the handle had 2 screws in it. I tightened the screws back down and clipped the handle back on. I am not an appliance pro, I am only speaking thru my own experience. Please be careful when you do this. If you feel it is too risky, then wait for a response from a pro.
Jul 12, 2014 | Frigidaire FFU14M5HW Upright Freezers
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Loose handle
bottom of handle is a screw hidden behind a square little sticker thing. use a small screwdriver to pry it out. take out screw and then push handle upwards and it will come off a clip which you can now tighten. then snap top secti0on of handle back onto clip and then lower screw secures it.
Nov 09, 2009 | Freezers
Have an Amana Side by side refrig/freezer (model ACD2234HRS) that has a loose refrig door handle. How do you get access to tighten the door handle screws?
i believe there are plastic coverings that just pop off. they are located at the hinge,you will need to fully open the doors to get to them.
Sep 20, 2009 | Freezers
Frigidaire modle ffu21f5hwb door handle loose how
Pop out the screw hole covers and tighten the screws.
Sep 16, 2009 | Frigidaire Freezers
How do I remove the handle of an upright Kenmore freezer. It is loose and I want to tighten it, but cant get it off. Thanks
The screws usually go from inside out and are under the inside panel. Unless you have the universal handles that switch sides and there is a screw on to and one on bottom.
Aug 26, 2009 | Freezers
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
Nov 24, 2008 | Freezers
Electrolux Genuine Frigidaire Refrigerator Door Handle 218428101 Logo
179 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
