Question about Curtis Televison & Video
My sound has stopped working
The screen has a perfect picture but my sound stopped working last night. I have had the cable company reset the cable TV, changed the batteries
    Top Expert:
  • Curtis Master
  • 74,136 Answers
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Nov 29, 2014
SOURCE: No picture on screen
Help...How can I talk to a person ..2 year old Protron 32" LCD went out last night /nothing was touched...no pick or sound..it's like their is no elcetricity going through..no lights on. Could it be the DC adapter? the blue light is not on the adapter(is it to stay on?) It goes on when I first plug it in then goes off.
Posted on Dec 13, 2007
Shuttle83
  • 1139 Answers
SOURCE: toshiba 50in plasma
Hello brattbabie1,
Ok you have sound and no picture. This denotes that since this is a plasma TV the circuitry that controls the activation of the screen may have become defective. You will need the schematic to show the voltage levels that need to be present on the cable that connects between the screen and the control circuit and a voltmeter to measure those voltages. I would suggest that you get a qualified TV technician to work on this problem, due to the technical nature of this issue.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 10, 2008
tvguy171
  • 106 Answers
SOURCE: no picture -- white screen -- no sound
With no video and the the colored stripes, it sounds like the LVDS cable needs to be reconnected to the LCD control board or the control board itself is bad. If the unit is only 3-4 months old, it should be covered by warranty
Posted on Nov 26, 2008
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 1768 Answers
SOURCE: sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Posted on Feb 05, 2010
I have no sound but perfect picture TCL l32m61az can you help
Remove set and a cable or sat box or a receiver if in line , remove all from power for several minutes and then power back, a reboot may help and cannot hurt.
Dec 12, 2012 | Televison & Video
I have a black screen. Cable company says I have
This is a common problem with Cable companies when they update their firmware. This makes the two incompatible. You can try going onto www.samsung.com and look for firmware updates for your model. Follow the instructions provided. If this does not work then you have a bad cable box. Cables companies are notorious for blaming the tv. Don't let them fool you. Stand your ground and insist on them correcting the problem.
Apr 15, 2010 | Samsung LN-T3253H 32 in. LCD Television
Sony kdl-40v5100 has handshake problem
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
NO Picture or Sound
sounds like someone rolled over on the remote. if you have cable or a dish, the tv channel must be left on a specific station at all times. no matter what channel is on the cable, the television itself must be on the correct channel number in order to receive he signal from the cable company. try hitting the last channel recall button on the tv, not the cable. otherwise try channel 3 or 4 or sometimes 60 on the tv. good luck
Nov 11, 2009 | Televison & Video
All of a sudden ...no sound
The Time Warner support walked me through getting my SAP turned off on the CABLE BOX.
Nov 06, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Toshiba 50in plasma
Hello brattbabie1,
I hope this helps,
Thank you,
Shuttle83
Aug 09, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Picture but no sound
it happens to me alot lately i think its the actual hdmi port of the ps3 just unplug the hdmi cable and plug in and it should work just fine.
Jun 18, 2008 | Sony Playstation 3 (PS3) Console
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
No picture
It sounds Like you Had Horz Failure In your Set,The Squealing you Heard was Probly the Horz Output Transistor,You will Probley have to take it to a Shop
Jul 17, 2007 | Insignia IS 20" TV040919 TV
Televison & Video Logo
93 people viewed this question
Top Curtis Televison & Video Experts
Martin Murray
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
