Question about Panasonic VIERA Televison & Video
I have plugged my PS2 into my Panasonic Viera TV. Problem is that it will not let me access any other AV input other than the DVD player. Is there any way to add another AV input option?
    Top Expert:
  • Panasonic Master
  • 74,243 Answers
Refer its user manual. If you find no solution with it too; contact the authorized service center. http://electronicshelponline.blogspot.com/
Posted on Nov 29, 2014
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
Coldcut
  • 1554 Answers
SOURCE: Accessing External Inputs Settings
you have to use the remote control for the tv not the dvr.
the dvr control likely cannot control the tv inputs programming unless you can program the correct code. and most new lcd panels don't have the correct codes for existing remotes
access using ext on the tv remote.
you may have to go into the menu and tell the tv what the ext is set to ie.. a channel or a input.
Posted on Feb 18, 2008
skotkolr
  • 558 Answers
SOURCE: Panasonic Viera
vga board is bad ot the components on it are blown out.
Posted on May 08, 2008
SOURCE: Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Posted on Jan 05, 2009
  • 1039 Answers
SOURCE: Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
Posted on Apr 25, 2009
I'm trying to plug my ps-3 to my panasonic viera th-50pz80u with an AV multi-out but i have no signal. No sounds, no images. Please help me
In your PS3 configuration you'll likely have to set the PS3 so that it is using the multi-AV rather than HDMI.(In Video Output Settings) Also on the TV input you'll have to select composite in rather than HDMI.
https://support.us.playstation.com/app/answers/detail/a_id/788
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Hope this helps,
Jeff
Nov 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
I want the steps to connect playstation 2 to my Panasonic Viera tv
I have panasonic viera led , push AV on remote end pot on AV2. It works fantastic.
Aug 25, 2012 | Sony PlayStation 2 (PS2) Console
I cannot record from a Daewoo DVD recorder ( 8150P) through my Viera TV ( model TX-L32S20B ). The screen says No Signal and instructs me to check inputs. I've tried using all cominations of AV1 and AV2...
If you want to record from the TV to the DVD recorder you have to first select a channel on the TV that you want to record and then take an AV cable ( Yellow / Red / White ) and connect from the Monitor out socket of the TV to the AV in of the Daewoo DVD recorder. Drop a blank DVD select AV on the Recorder and press the record button.
Mar 08, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
How to get dvb chanels on my tv ?
If you're talking about the DVD then it will depend on what input you have it plugged in to. Follow the cable from your DVD player to your tv and read the name of the plug it is labled with. Hit TV/Video on your remote several times until it gets to that lable on the screen. example, If you have you DVD plugged in to Video 1, hit tv/video button on your remote or on your tv until the cursor highlights video 1. Movie should play.
May 19, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
How to connect nintendo 64 to panasonic viera tv
it depends what connector cable you have if you have an AV cable hook it into the red white and yellow colored inputs if you have an RS cable for the 64 screw this into the back of the tv where the antenna input is.
Oct 27, 2009 | Panasonic CT-27E13 27" TV
Finding AV channel to connect DVD to TV
first check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
Nov 16, 2008 | Sanyo DP42746 42 in. Plasma Television
Ps3 hookup to panasonic plasma viera
Actually if you do have a ps2 you don`t really need a Dvd upconverter because Ps3 is a full Dvd player +blu Ray Hi Definition.I suggest to take the dvd out and just use the ps3 as a Dvd player
Good Luck
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
