Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
How can I know the manual on/off switch is in the ON position? It just keeps rotating counterclockwise and the lights never come on.
Tried changing time of day on the clock and adjusting pins. The manual on/off switch just keeps rotating counter-clockwise, but the lights do not turn on.
  • Malibu Master
  • 5,245 Answers
2 Suggested Answers
SOURCE: Timer not working?
look closer at those pins as the motor turns those pins turn a togle switch on and off make sure those pins are able to togle that switch you will see that switch under the that timer disk
Posted on Apr 26, 2010
I replaced my ignition cylinder lock and switch in my 1993 Jeep Grand Cherokee limited 5.2 Liter V-8 and when I reassembled it and started it my power windows and V.I.C. don't work? Help please
replaced my ignition cylinder Anon, Check your fuses, also after changing ignition, google search if you have to do a relearn procedure.
Mar 31, 2016 | Jeep Cars & Trucks
I just bought an older whirlpool dyer (MOD wed5300sq0 type dwjr-ele-2406026-fm54) and it spins counterclockwise. Is that an issue? The heat is blowing out of the house in the correct direction but I didn't...
The drum on the dryer is powered by an ac motor. You cannot change its direction of rotation by changing lead connections. AC has no positive or negative leads. It must be OK as is
Oct 29, 2014 | Dryers
How to change break light switch in Buick
  1. Remove the left sound insulator.
  2. Rotate the stop lamp/ABS/shift lock switch (2) counterclockwise, then pull to remove the switch.
  3. Disconnect the electrical connector from the switch
Oct 02, 2014 | 2002 Buick LeSabre
How do i change out the ignition switch?
Ign Systems 8D - 19 Service manual '92 Dak
Disconnect neg battery cable Tilt column:Remove tilt lever (counterclockwise) Remove upper and lower covers (3 screws) Remove ign switch mounting screws (3) with torx bit Gently pull switch away from column Release two connector locks on the seven-terminal wiring connector. Remove connector from ign switch Release connector lock on the Key-in-switch and Halo Light four terminal connector. Remove connector from switch Remove key cylinder from switch as follows: With key inserted and ign switch in the LOCK position use small screwdriver to depress the key cylinder retaining pin flush w/ key cylinder surface Rotate the key clockwise to the OFF position The key cylinder should now be unseated from the ign switch assembly With key cylinder in unseated position (key cylinder bezel about 1/8 inch above ign switch halo light ring) Rotate key counterclockwise to LOCK position and remove key Remove key cylinder INSTALLATION; Install electrical connectors to switch making sure locking tabs are fully seated into connector Mount ign switch to column Shifter must be in PARK position Park-lock dowel pin on ign assy must engage with park-lock slider linkageVerify ign switch is in lock position (flag is parallel w/ ign switch terminals..off to the right) Apply dab of grease to flag and pin Position park-lock link and slider to mid-travel Position ign switch against lock housing face Be sure pin is inserted into park-lock link contour slot Tighten screws Assemble cover Tighten more screws Tilt column and install tilt lever (clockwise) instsall neg battery cable Gently insert key cylinder into ign switch asssy until it bottoms Insert key and gently push key (inward) and rotate clockwise to end of travel Rejoice in how much money you just saved yourself
Jun 16, 2014 | 1992 Dodge Dakota
Do I have to remove the tray liner from the 2003 Rodeo pick up to replace tail light assembly?
Utility And Sportside Pick-Up Models
  1. Make sure the headlight switch is off and the ignition switch is in the lock position.
  2. Unfasten the screws retaining the lens, then remove the lens.
  3. Disconnect the bulb socket from the license plate lamp by rotating it 1/4 of a turn counterclockwise.
  4. Remove the bulb from the socket.
  5. Installation is the reverse of removal.
    Without A Step Bumper
    2. Disconnect the bulb socket from the license plate lamp by rotating it 1/4 of a turn counterclockwise.
    3. Pull the bulb from the socket.
    4. If necessary, remove the lens retaining clip and the lens from the filler panel.
      With A Step Bumper
      2. If necessary, lift the lamp up and tilt the bottom away from the bumper to release the lamp retainer.
      4. Pull the bulb from the socket.
      5. If necessary, remove the step bumper pad, the screws that attach the lamp to the bumper and remove the lamp assembly.
      6. Installation is the reverse of removal. Tighten the lamp assembly-to-bumper screws to 14 inch lbs. (1.6 Nm).
Dec 12, 2010 | Isuzu Pickup Cars & Trucks
Had the battery changed, but now the (heat) vents in the top of the van and the floor vent (heat) does not work - only cold air comes out. Also, the heating/cooling dial lets it get hot midway on cold...
Try this calibration procedure and let us know if you have more questions:
  1. Start the vehicle.
  2. Wait 40 seconds for the HVAC control module to self-calibrate.
  3. Verify that no DTCs have set as current DTCs.
  4. Clear all DTCs.
  5. Place the ignition switch to the OFF position.
  6. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  7. Rotate the Mode knob fully counterclockwise.
  8. Rotate the Mode knob fully clockwise.
  9. Rotate the Mode knob fully counterclockwise.
  10. Release the AC button.
  11. Wait 40 seconds for the HVAC control module to self-calibrate.
  12. Start the vehicle.
  13. Verify that no DTCs have set as current DTCs.
Nov 14, 2010 | 2005 Pontiac Montana SV6
Why my new oster blender blade rotates counterclockwise and not clockwise?
It is a function of gearing or motor orientation, and it makes no difference which way it rotates, as long as all of the attachments need the same rotation....
Nov 06, 2010 | Microwave Ovens
I own a 2006 Pontiac Montana SV6, there is very little heat coming from the heater, a/c working fine, fan blowing full capacity. Could it be the thermostat.
probably the blend door not opening fully. Do you hear a clicking under the dash by passenger's feet? If not, try calibrating the system:
  1. Place the ignition switch to the OFF position.
  2. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  3. Rotate the Mode knob fully counterclockwise.
  4. Rotate the Mode knob fully clockwise.
  5. Rotate the Mode knob fully counterclockwise.
  6. Release the AC button.
  7. Wait 40 seconds for the HVAC control module to self-calibrate.
  8. Start the vehicle.
If this doesn't work, your actuator may have failed. Look under the dash to see if any of the actuators on the heater box are trying to turn when you change the temperature setting. Unfortunately, I cannot find aftermarket parts for your heater, so if the door isn't working you may need to go to the pontiac dealer. Let me know if you have questions.
Oct 22, 2010 | 2006 Pontiac Montana SV6
Timer not working?
Apr 26, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Where can I get a manual for this 35 mm camera? Canon does not have one on line.
The dial has six positions. If you rotate the dial fully clockwise, you are at the "Auto" position. In this position, the flash will fire if light is insufficient.
One click counterclockwise from this is "Auto with Redeye Reduction", and a preflash lamp will fire before the shutter to reduce redeye.
The next click counterclockwise is the "Off" position.
The next click counterclockwise is the "Flash On" position, and the flash will always fire with the shutter.
The next click counterclockwise is the "Flash Off" position, and the flash will not fire.
Full counterclockwise is the "Self Timer" position, and the shutter will fire 10 seconds after the button is depressed.
Mar 09, 2008 | Canon Sure Shot 80 Tele/Date 35mm Point...
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
111 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
 Kenneth
Kenneth
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
