Question about Coffee Makers & Espresso Machines
My delonghi magnifica esam 3300 does not turn off and continuosly make coffee until I unplug the power cable.
  • moises pontes Dec 03, 2014
    If I plug the power cable to the outlet it starts automatically, clean the machine and makes coffee, but it does not stop working, continuous to make coffee and after 3 times stops. The off switch does not work and to turn off the coffee machine I have to unplug the power cable from the outlet.
Your question: "I have a Delonghi magnifica 3300 that is 7 yrs old. It doesn't heat the coffee very good and the steam frother doesn't work well either. I have always used filtered water and descale i
If heater not working properly ,but still working the heat transfer poor ,probably need to disassemble and actually manually clean heater unit with wire brush till really clean,otherwise replace heater unit as heaters are usually fully sealed. get on line and search for Delonghi magnifica 3300 (parts diagram , replacement parts,parts). then you will have part no and hopefully someone who can supply parts.As for frother if water not heating to enough to make hot coffee the not heating enough to make steam either so frother does not work,if blocked then need to clean out frother tube.
Sep 07, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Magnifica ESAM 3500 milk temperature low
This is factory preset and cannot be altered. You do need to use the "clean" function on the milk frother unit to ensure the boiler and pipes heat up enough also.
May 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
How to replace Delonghi magnifica esam 3300 hot water/steam Adjustment knob ? Try around but can not take it out ...
ha this is the same problem i had just last week at a customers house with the same machine , the knob does pull off but it is hellish tight and you feel like the valve is about to burst through the front of the machine but it does pull off, when fitting the new knob it is a good idea to put some grease over the shaft before pushing the new knob on as it's nearly as hard pushing the new one back on as taking the old one off.
regards
Ian
Apr 17, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling coffee makes esam4200
100ml of descaler per tank of water. then they say 1 rinse, but I have to rinse 5 times to not taste the descaler anymore.
Jul 21, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Apr 22, 2010 | DeLonghi Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
