Question about GMC 98 99 00 01 Blazer S-10 Jimmy Bravada 4x4 Transfer Case Computer
98 gmc jimmy 4.3 v6 auto trans 4x4 was shifting good then kicked out of gear and only goes to 1sy and 2nd gear no higher wat can it be I changed filter and fluid
Trans was working good didn't shift hard before it kicked out don't understand I changed filter and fluid hoping to fix but still doing it
  • GMC Master
  • 3,904 Answers
You are probably too late for just a fluid change. You can dig into the shift solenoids which you can replace yourself but anything else I would hire someone to do it for you.
Posted on Jan 14, 2015
2 Suggested Answers
SOURCE: How Do I Test the Fuel Pressure Regulator, on a 98 GMC Jimmy with 4,3L
with a fuel pressure tester
Posted on Nov 19, 2012
Transmission not shifting into high gear since abs/4x4 code
answer to any 4l60e trouble ' GMT400 - The Ultimate 88-98 GM Truck ...
www.gmt400.com > Street and Track > Transmissions
Mar 5, 2011 - Before guessing at transmission problems, check the fluid level (car warmed up, ... that do not show up as PCM codes (like shift A&B solenoid failures, for example). ... 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for ...goes into 3rd gear: Reaction planetary is worn out due to high miles or ...
GMC Jimmy Transmission Problems - Edmunds
forums.edmunds.com > GMC > GMC Jimmy
Dec 20, 2013 - 1998 Jimmy After truck warms up shifts hard between 1st and 2nd gears. any ideas ... The ABS light stays on,the engine light stay on, the speedo doesn't work, .... I have a 1990 S15 4x4 Jimmy with a manual 5 speed transmission that went out. .... While driving it will only shift into 2nd gear and 3rd no overdrive. and usually ... Ford F-Series Transmission Problems - Edmunds
Dec 18, 2013
Buick Rendezvous Transmission and AWD Problems - Edmunds
Dec 18, 2013
Dodge Dakota Transmission Problems - Car Forums at Edmunds.com
Dec 18, 2013
Ford Transmission Problems - Edmunds
May 14, 1998
More results from forums.edmunds.com
Automatic Transmission May Not Shift Correctly at High ...
repairpal.com > Problems > Toyota > 4Runner
Feb 03, 2016 | Cars & Trucks
2000 GMC Jimmy 4x4 Switch not working and Shifting hard between 1st and 2nd
Change the switch itself if it drives normal then randomally kicks into 4 lo/4 hi i had the same problem and a transmission shop told me it was the vaccum and the transfer case but one of my mechanic friends told me that it was my switch and shops only tell you other things for the money. Try changing the switch.
Aug 12, 2012 | 2000 GMC Jimmy
How do you adjust the shift cable on a 1995 gmc jimmy, wont go into reverse or park.
On the 1995 Jimmy, the shift cable can come loose on the mount on the side of the transmission where the cable meets the trans. When it slips, the alignment goes off and causes the driver to not be able to put the trans into park. If you take a long stick you can push the shift arm on the trans to the park position and your trans will go into park.....what you (and I) really need to know is how to take the shift cable mount apart and reset it.
Aug 05, 2012 | GMC Jimmy Cars & Trucks
How to use the 4x4
well, if you are sitting still it is recommended you put vehicle in neutral and select 4x4 indicator to desired posistion..... 4 high...4 low...or 2high (auto) when you select 4 low the top speed is not to exceed 25 mph. It is a very low gear for crawling or pulling. At any time you need 4 low gear you must stop trk, shift to neutral and select 4 low. The same procedure is done to change from 4 low to 4 hi or 2 hi. if not done this way internal trans, transfer case or driveline failure will occure. At any time you may shift 4x4 selector from (auto) or 2 hi to 4 hi, and 4 hi to 2 hi or( auto).****** But note, do not make shifts while tires are spinning or under power (acceleration)******* While driving you can make shifts at any speed between 2 hi (auto) and 4 hi and back to 2 hi. release throttle a little and select. you do not have to take foot off throttle all the way! just enough that truck is not under a power, load acceleration. If tires are spinning or you are on the gas and you select gears from 2 & 4 high the posibilities of severe damage can result. Also note that 4x4 is not recommended on dry pavement. When 4x4 is being used also take care as to the handling and the steering characteristics change, On tight turns the front wheels will bind and possibly **** a little. If you have never had a 4x4 before, obey what i have told you untill you get the experiance and you will be fine. HAPPY TRAILS.... AND A LITTLE 4X4 FUN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jan 12, 2011 | 1998 GMC Jimmy
1996 gmc jimmy won`t shift from 1st to 2nd
IF the abs dash light is on and if the speedometer is sluggish or not working at all, it is probably a bad speed sensor on the transmission. and easy fix under $40 for the part. Mine was stuck in second gear for a while then worked then it stuck in first gear and i had the CHECK ENGINE light on.
Dec 03, 2009 | 1996 GMC Jimmy
I have a 1995 GMC Jimmy with auto trans., it wont shift into 2nd gear only shifts into drive when I get up to 2700 RPM and let off the gas and wont shift into overdrive at all. Does anyone know what causes...
Your going to have to get the Jimmy scaned before youhurt the transmission, It sounds like it's on a Limp mode which can range from a tune up to a bad ground. Good luck.
Mar 17, 2009 | 1995 GMC Jimmy
2001 GMC Jimmy rough jump into 1st & 2nd gear after a stop
Had the same problem on my 2001 GMC Jimmy, but my reverse was also out!!!! Was the transmission!!! But it also did the same thing when starting from a dead stop! Had to rev up the RPMs to get it to shift, but once it got into the higher gears, it drove fine!!!! My mother also had a 2001 GM S-10 with the same problem and it was her tranny as well!!! Hope this is not your problem because it is not cheap........a friendly mechanic charged $1300 to replace the tranny with a used one with lower miles!! He also said that these models of GMs were notorious because the spline gear used in these models were made of a lower grade of metal and were prone to wear out prematurely!!!!! I also first suspected the shift sensor before I talked to a professional!!!!!
Mar 07, 2009 | 2001 GMC Jimmy
4x4 not wprking in my 98 blazer
replace the actuater 59.00 at auto zone
Mar 06, 2009 | 1998 GMC Jimmy
GMC 98 99 00 01 Blazer S-10 Jimmy Bravada 4x4 Transfer Case Computer Logo
95 people viewed this question
Top GMC Computers & Internet Experts
bigdawg7299
Jeff Armer
David Ellis Rhea
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
