How and with what product do i replace a rvp infared transmiiter to a wall thermostat to run my heat and a/c in my rv ? it is a keystone 2007 5th wheel. It has a control unit on a/c and does not keep
Ive heard that there is a new control box and you have to do so re-0wiring
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
The infrared transmitter is the remote control. Do you have one ?
If so, first replace the internal battery. If this does not help you would have to buy a new remote .
Posted on Nov 30, 2014
kstfas
  • 75 Answers
SOURCE: Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Posted on Sep 23, 2007
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
SOURCE: Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Posted on Nov 18, 2008
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
Tip
Coleman RV Air Conditioner Service and Repair Questions
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
They can also answer RV Thermostat and wiring questions.
on Dec 29, 2009 | Heating & Cooling
Tip
Coleman RV Products
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
GO TO rvcomfort.com
on Dec 28, 2009 | Heating & Cooling
Runs fine but only runs for 5 min then shuts off for 5 min then back on, will not stay running.
GO TO rvcomfort.com
Jul 25, 2010 | Coleman Mach III Air Conditioner
I have a colman mach thermostat model 7330D3351 heat/cool I need to know how to reset my unit.
GO TO rvcomfort.com
Jan 15, 2010 | Heating & Cooling
Where can i buy a thermostat control box for a coleman 7000 rv air cond
GO TO rvcomfort.com
Oct 10, 2009 | Heating & Cooling
Colman unit is getting no power
GO TO rvcomfort.com
Sep 10, 2009 | Coleman Mach III Air Conditioner
I would like to run a coleman rv roof air conditioner Mod # 6727-736 on the bench before installing on the Rv. It is a used unit. The plugin has 6 wires. I wont to see if the compressor is still...
GO TO
www.rvcomfort.com
May 09, 2009 | Heating & Cooling
We have a rooftop coleman air conditioner on our RV. When it runs it trips water on the counter top instead of draining on the roof. I don't know how to fix it
GO TO rvcomfort.com
Apr 20, 2009 | Coleman Heating & Cooling
Dometic duo therm a/c for rv
generally most R/v dealers should have those replacement parts they will have detailed diagrams that you can tell them exactly what you need
Aug 28, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
