Question about Radio Communications
<!-- from fixya rte -->Adjust tone burst on ic228h - Radio Communications
    Master:
  • 623 Answers
Go to the link below and get the manual, it will explain everything... RigPix Database Icom IC 228H
Posted on Nov 29, 2014
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
How do you set the key pad to silent?
Hi to adjust the volume of keypad tone you need to Adjust the volume of the key tones
In Idle mode, press [Up /Down ] to adjust the key tone
volume.
Let me know if this will solve your prob
Nov 27, 2009 | Samsung B2100 Cell Phone
Have a series of 5 chimes 5 times believe its
The secondary air bag warning is an audible fault format that consists of five sets of five tone bursts, with each set of five tone bursts separated by a five second quiet period. One tone burst cycle will consist of one second ON and one second OFF. This series of five activations is repeated every 30 minutes.
This will tone if the air bag indicator is inoperative.
Suggest to have the dealer or someone with a scan tool that will communicate with the restraint system retrieve codes.
Mar 16, 2009 | 2002 Ford Escape
COLOR TONE NOT WORKING
ntsc and pal is just systems for processing your antenna signals weather be cable or outside, the color or tint circuits are downstream of this. tint is the phase adjustment of a color burst that rides on the horizontal sync pulse before it hits your color amplifiers. Ntsc is US and Canada, Mexico, basicly a Western standard here.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Hughes SD-HBH Satellite Multiswitch Compatability
DiSEqC Tone burst multiswitch are not compatible with directv equip
Dec 31, 2008 | Hughes SDHBH DirecTV DTV Receiver
I get a dial tone / cannot dial out
put the phone to your ear and press any digit---you should hear a short burst of tone--if not you may be analogue pulsing which takes forever wait wait wait or change your phone to send tones instead.do this or check this in the menu for whatever kind of phone you are using....i hope this helps
Dec 20, 2008 | AT&T E2811 2.4 GHz Cordless Phone
Tone adjustment
If it have no tone control simply add a tone control accross the volume controll and add two capacitors on both end of the tone controll as shown in figure
Jan 16, 2008 | GE 7-5295 Undercounter DC /Radio Combo -...
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
Radio Communications Logo
61 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
