Question about Cell Phones
HOW TO PROGRAME GSM REMOTE CAMERA TO RECEIVE MMS PICTURES ON THREE.CO.UK NETWORK
SET APN AND MMSC
Apn settings for safetynet wireless lifeline on my kyocera zte N3192
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_a4640839dbb7ec58
Mar 21, 2018 | Kyocera Cell Phones
Tip
Gprs & MMs settings for england cellphone networks
&gt;T-MOBILE GPRS SETTING <br /> <span> </span>#Account Name - T-MOBILE GPRS <br /> <span> </span>#Username : user <br /> <span> </span>#Password: wap <br /> <span> </span>#Homepage: http://wap.t-mobile.co.uk/ <br /> <span> </span>#GPRS APN address: general.t-mobile.uk <br /> <span> </span>#Gateway (IP) address :149.254.001.010 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Port number: 9201 <br /> <span> </span>#Authentication: Normal <br /> <span> </span>&gt;T-MOBILE MMS SETTING <br /> <span> </span>#AccountName:- T-Mobile <br /> <span> </span>#Data Bearer:- GPRS #User name:- mms <br /> <span> </span>#Password - T-mobile tell you this when you register <br /> <span> </span>#APN:- general.t-mobile.uk <br /> <span> </span>#IP address:- 149.254.211.10 <br /> <span> </span>#MMS Server:- http://mmsc.t-mobile.co.uk/ <br /> <span> </span>&gt;ORANGE GPRS SETTING <br /> <span> </span>#Account Name :- ORANGE GPRS <br /> <span> </span>#Homepage: http://orange.multimedia/ <br /> <span> </span>#APN address: orangewap <br /> <span> </span>#Gateway (IP) address : 192.168.071.035 <br /> <span> </span>#Username : Multimedia <br /> <span> </span>#Password: Orange <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: NormaL <br /> <span> </span>&gt;ORANGE MMS SETTING <br /> <span> </span>#AccountName:- Orange <br /> <span> </span>#Data Bearer:- GPRS <br /> <span> </span>#APN:- orangemms <br /> <span> </span>#User ID:- Orange <br /> <span> </span>#Password:- Multimedia <br /> <span> </span>#IP Address:- 192.168.224.10 <br /> <span> </span>#MMS Message Server:- http://mms.orange.co.uk/ <br /> <span> </span>&gt;VODAFONE GPRS & MMS SETTING <br /> <span> </span>#Account Name - VODAFONE GPRS <br /> <span> </span>#Homepage: http://wap:1999/vodafone.wml <br /> <span> </span>#APN address: wap.vodafone.co.uk <br /> <span> </span>#IP address: 212.183.137.12 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: Normal <br /> <span> </span>#Security: Off <br />
on Jan 11, 2011 | Cell Phones
Tip
Apple iPhone 3G/3GS O2 UK PAYG Settings
iPhone: How to set up the APN setting for O2 PAYG
The APN defines the network path for all data services i.e. internet & e-mail.
To edit the APN go to Settings > General > Network > Cellular Data Network
Cellular Data:
APN – payandgo.o2.co.uk
Username – vertigo
Password – password
MMS:
Username – payandgo
Password – payandgo
MMSC – http://mmsc.mms.o2.co.uk:8002
MMS Proxy – 193.113.200.195
You are now ready to use your iPhone to browse the internet & send MMS picture messages.
N.B Please ensure you have a data bundle attached to your account or you may incur additional charges on your account.
on Dec 01, 2009 | Cell Phones
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Why wont my mms work?
Make sure your 4g is on and make sure that your data plan is for 4g
Sep 10, 2014 | HTC One M8 32 GB Grey Smartphone - AT&T 2...
Tip
Apple iPhone 3G/3GS O2 UK Contract APN Settings
iPhone: How to set up the APN setting for O2 Contract
Cellular Data:
APN – mobile.o2.co.uk
Username – mobileweb
Password – password
MMS:
APN – wap.o2.co.uk
Username – wap
Password – wap
Tip
Apple iPhone 3G/3GS Vodafone APN Settings
iPhone: How to set up the APN setting for Vodafone
Cellular Data:
APN – internet
Username – web
Password – web
MMS:
APN – wap.vodafone.co.uk
Username – wap
Password – wap
MMSC – http://mms.vodafone.co.uk/servlets/mms/
MMS Proxy – 212.183.137.12
Can you send me the giffgaff settings for a sony xperia play R800i
Internet settings
APN - Access Point Name
: giffgaff.com
Login - Username: giffgaff
Password: [leave blank]
Proxy: [leave blank]
MCC: 234
MNC: 10
MMS settings
APN - Access Point Name: giffgaff.com
Username: giffgaff
Server: http://mmsc.mediamessaging.co.uk:8002
MMSC: http://mmsc.mediamessaging.co.uk:8002
MMS proxy: 82.132.254.1
MMS port: 8080
MCC: 234
MNC: 10
APN type: mms
May 27, 2014 | Cell Phones
Has anybody used GSM remote camera V900 model in Europe. I suspect the MMS settings (network settings) are not in order. Any tips / help on this much appreciated.
here are settings that work for tmobile usa
#124#216.155.174.84/servlets/mms#
#125#216.155.165.50#9201#wap.voicestream.com#
these were given to me by the folks i bought it from in china, they do work for tmobile usa. it is being used with a prepaid sim.
Feb 09, 2010 | Cell Phones
Tip
Apple iPhone 3G/3GS Orange UK APN Settings
iPhone: How to set up the APN setting for Orange Contract
Cellular Data:
APN – orangeinternet
Username – user
Password – pass
MMS:
APN – orangemms
Username – Orange
Password – Multimedia
MMSC – http://mms.orange.co.uk/
MMS Proxy –
192.168.224.10:8080
Max Message Size - 307200
MMS UA Prof URL - Leave blank
Next you need to edit "Your number"
Go to Settings > Phone > My Number> You need to change the number to +44 yournumber e.g. +44 7897123456
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
