Question about Dryers
How to replace drum paddle lifter - Dryers
You will first need to post the manufacturer and complete model number of the dryer if you want an answer to your question.
there are dozens of manufacturers and thousands of models.
Posted on Dec 01, 2014
Replacing Drum paddle lifter for Asko washing machine?
BIG JOB !! The machine will have to be fully stripped down as the only access to the paddle is by removal of the spin bowl itself from the machine. The paddles usually are held on at the front and along the sides by moulded clips that slide into the tub and are secured at 1 end by a set screw. If I remember correctly, the entire bowl assembly is removed through the front of the machine. The top and front have to be taken off to do this. Its a huge job, it may pay to obtain the services of someone who has done this before.
Jan 02, 2015 | Asko Washing Machines
How can I replace the drum paddle on my zanussi zwf16070w1
Insert a screwdriver into the fourth hole in the lifter (paddle) and
bend back the anchor tabs. Pull the lifter outwards (towards the door) and detach from the drum. To insert the new lifter into the drum is needed to disconnect the tube between the tub and filter housing, than tighten the screw (through the hole in the tub) to secure the lifter to the drum.
Dado
Nov 29, 2014 | Zanussi Washing Machines
Where can I purchase a replacement drum paddle lifter for my old bauknecht tumble dryer TRA965?
HELLO.
The best way to get the drum paddle replacement is to visit the manufacturer website to order for it stating the microwave oven model number and give your house detailed address.
However the
drum paddle can also be purchase at any microwave oven authorized dealers around your local area with the model number for compactibility(easy use).
Thanks
Sep 21, 2011 | Microwave Ovens
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WD860
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
50 people viewed this question
Top Dryers Experts
