<!-- from fixya rte -->How do I replace the drum paddle - Washing Machines
Where can I purchase a replacement drum paddle lifter for my old bauknecht tumble dryer TRA965?
HELLO.
The best way to get the drum paddle replacement is to visit the manufacturer website to order for it stating the microwave oven model number and give your house detailed address.
However the
drum paddle can also be purchase at any microwave oven authorized dealers around your local area with the model number for compactibility(easy use).
Thanks
Sep 21, 2011 | Microwave Ovens
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Plastic padle on inside of drum broken
Yes the paddles can be replaced. www.bellparts.com type in your model # and locate the paddles.
I hope this helps you.
Vic
Jul 12, 2009 | Washing Machines
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Loose Paddle in the Drum
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
Feb 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
