Sam4s er180. The printer is not printing numbers on till roll. Although the transaction codes are printing
The register roll has ceased printing out a receipt for sales.
make sure you have it set to print and that you have your id number punched in
Jul 08, 2015 | Sam4s ER-180T Cash Register
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
Till roll re-placement not printing
Try turning paper around or make sure you have thermal paper if it is a thermal printer model
Jun 18, 2014 | Casio Parts Cash Register PC Desktop
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Jan 28, 2014 | Sam4s Samsung Er-290 Cash Register
Till roll print says power fail. cannot open the cash draw.
The power has been turned of before the sale was finished. Make sure it has a new roll of paper in the printer, then turn key to PGM and switch the power off. Hold down the SUBT key while you turn on the power - display will say INITIAL or something similar. Turn key back to R and see if it works.
Dec 23, 2013 | Samsung SAM4s ER-650 Cash Register
I have a VeriFone Omni Vx510 - I keep getting a paper out message when trying to process a transaction. There is paper in the machine.
If the printer does not work properly:
• Check battery status or terminal power connection. The printer will not print if
there is an insufficient charge remaining in the battery to complete the print
operation. (For Vx610 terminals only.)
• Check if the printer is out of paper and that the roll is properly installed. Open
the paper roll cover and install a new roll of printer paper or ensure that the roll
is feeding from the bottom.
• Verify that the printer roller and paper roll dust cover are properly installed.
• If the problem persists, contact 775-358-2922 hope this help : - )
Sep 13, 2011 | VeriFone (M19755014US1) Magnetic Card...
Replaced paper in Omni 3750, now it feeds but doesn't print
Make sure you are using thermal paper and it is feeding from the bottom of the roll. If not press down on the lid when the paper is printing sometmes the tension springs were defective.
Feb 19, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
My cash register is not printing.
Hi.
If it is a thermal printer, make sure you have the paper coming from the bottom of the roll, not the top. If you have the paper the wrong way around, it will come out blank.
If this is not the problem, please let me know the model number and any other information you can give.
Mark
Dec 08, 2008 | Casio Parts Cash Register PC Desktop
26 people viewed this question
jasbo
jasbo
