Question about Singer Sewing Machines
Bobbin thread not picking up
Singer 7444. The bobbin thread not engaged at all
    Problem Solver:
  • 6 Answers
It sounds like the timing belt has jumped. You will need to take it in to a sewing machine repair shop as there is no info available to reset the timing.
Posted on Nov 29, 2014
4 Suggested Answers
  • 69 Answers
SOURCE: Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Posted on Mar 01, 2009
SOURCE: Bobbin thread won't pick up
try changing the needle
rethread the machine top & bobbin
if these suggestions don't help the it's possible that the machine is out of time & needs to be serviced
Posted on May 29, 2012
SOURCE: Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Posted on Jul 30, 2012
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
May 11, 2012 | Singer 7444 Mechanical Sewing Machine
Cant pick up thread from bobbin
Check your needle to see if it's damaged
Check the bobbin to see if it's warped
Check the bobbin to see if it's inserted in the bobbin case correctly
Check the bobbin case to see if it's inserted properly in the machine
Make sure there's no lint or loose thread in the bobbin area
If these suggestions don't work then it could be the timing is off just a little & it needs to be serviced
Oct 01, 2010 | Singer 7444 Mechanical Sewing Machine
How to thread bobbin on Singer Precision 7444 Sewing Machine
Have you got the manual?
If not, you can download one free from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 7444 and click on search.
On the next page choose the free download option.
Pages 16 anfd 18 of the pdf file will tell you how to wind and thread the bobbin.
Hope this helps!
Sep 22, 2010 | Singer 7442 Mechanical Sewing Machine
Machine locked up and makes a beeping sound it is a Singer 7444 the hand wheel is frozen
There may be thread caught in the bobbin area.
Turn off the power and check the manual for maintenance.
Once the area is clean and the bobbin case back in place, turn the machine back on.
If this does not resolve the issue, the machine will need an authorized sewing machine tech to repair it.
Mar 13, 2010 | Singer 7444 Mechanical Sewing Machine
Wont pick up bobbin thread
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
Oct 02, 2009 | Singer 7444 Mechanical Sewing Machine
Hi I am pretty sure that the bobbin and the thread are in correctly but when I put the material in the needle just put holes in the material. what am I doing wrong?
you may have adjusted the upper tension and made it so tight that the thread just pulls out of the needle and needle makes holes in fabric. you might want to check the feed of the bobbin, it will not allow the machine to sew if it is not able to be picked up by the needle. the bobbin thread is usually (when held in your hand) with the thread coming counter clock wise. and then it will lay in the bobbin holder and the end of the thread will come back to about the slide catch thing and be held there until the needle thread catches it (leave the cover off the bobbin area until you watch and see what happens then. Try adjusting the bobbing tension too hope you understand what I mean here.
Mar 07, 2009 | Singer 7444 Mechanical Sewing Machine
Feb 28, 2009 | Singer 3116 Simple
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sewing Machines Logo
51 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
