Question about HP Scanjet G2410 Flatbed Scanner
How to clean glass
Let me know how to clean glass
  • HP Master
  • 3,904 Answers
Any household spray like windex will work fine.
Posted on Nov 30, 2014
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How do I clean the inside of the glass of the fireplace?
Crumple up newspaper, use it like a rag, scrubbing the glass. Not abrasive enough to scratch the glass but enough to clean soot deposits.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to clean your Fireplace Glass
Gas Fireplace Repair Dirty Glass My Gas Fireplace Repair
How To Clean Your Wood Stove Fireplace Glass
Cleaning glass on woodburner
Mar 02, 2016 | Heating & Cooling
How to replace a broken scanner glass canon dr1210c
I don't know how the CANON DR 1210-C is assembled but I had an Artec and unscrewing it I could take off the glass.
Oct 12, 2014 | Canon DR-1210C Scanner
Howto Clean the glass shelves in my LG refrigerator
Will they go in the dishwasher? If not, use an old toothbrush to get into the edges; use lemon juice or vinegar to degrease, rather than a bleach.
Apr 24, 2014 | LG Refrigerators
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
I have a ricoh 2232c. Do you know how I can clean
In order to clean the optics, you have to remove the two optic covers (one over the **** glass on the left and one on the rear side of the main platen glass). Each cover should have 2 or 3 screws.
Clean the **** glass and platen glass with alcohol and a lint-free rag (both sides) and blow compressed air onto the mirrors, lamp, and reflector. It's a good idea to turn off the copier before doing this.
When reassembling, clean the white strip on the underside of the **** glass cover as well.
May 08, 2010 | Ricoh Aficio 2232C Color Copier
Need adf adjustment have a black line on edge when using feeder
there is no need adjustment. i do not know for which model are you talk about but i will tell some basic instructions:
1. when you will lift the feeder see on the right side have one long vertical glass separated from the large glass.
2. clean that glass with soft and clean cloth but first apply some glass cleaning liquid.
3. after you will clean the glass see carefully do have some dot or some other dirty spots on the glass and clean them or if you need and scratch them out.
4. please rate this post if is helpful by doing that i will know do i should add some information and please write the machine model
Jan 11, 2010 | Office Equipment & Supplies
I need to clean the underside of the glass but don't know how to take the glass bed off.
if you are not an expert, you need caution to remove the glass for cleaning.
CAREFULNESS IS THE CODE
Nov 29, 2009 | Microtek SCANMAKER 4850 Flatbed Scanner
Need to clean the under side of the glass. Need
I found a service manual on-line that showed the method for removing the glass on the scanner.
Nov 16, 2009 | HP Office Equipment & Supplies
Glass Door stain
you can clean it but its not easy u have to remove the door put it on the floor remove the screws from the side and the bottom the glass should slide out then then u remove more screw to get the other piece of glass then u clean it and put it all back togather
Mar 16, 2009 | Kitchen Ranges
HP Scanjet G2410 Flatbed Scanner Logo
59 people viewed this question
Seeker5211
Seeker5211
