Samsung front load washer won't drain. Pump is new, water level is new, there are no clogs, main pub is good. Do I replace the control pcb?
JULIANFIX
  • 975 Answers
SOURCE: clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Posted on Apr 16, 2008
  • 120 Answers
SOURCE: How do I replace the pump on my front load washer? GLTF1240A
The pump may have an obstruction in it. It could be a coin or anything of that nature. The pump is located on the bottom front of the machine. If you have a removable panel on the front lower of the machine, remove that. There should be 2 screws to remove. There will be 2 hoses connected to the pump. Remove the hoses. (IMPORTANT...have a bowl or pan to catch the water otherwise it will go all over the floor...) There will be 2 screws holding the pump on. Before you remove the pump, turn the washer on so it will try to drain. See if the pump turns on. You will be able to hear if it is obstructed. After that remove the pump and look inside to see if anything is inside(ie.. coins ect.) If so remove them then repeat the process in reverse to get it back together.
Posted on Jun 02, 2009
  • 82 Answers
SOURCE: how do you drain the drain pump in lg front load
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
Posted on Jan 22, 2010
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
SOURCE: Kenmore 90 washer won't drain
How do I operate it? which program should i use for regular laundry?
Posted on Jul 08, 2010
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Why won't Affinity fill or spin?
Probably there is water in the drum or the pressure switch is jam in a state of "full of water" or washing machine didn't drain water .. So, the fault should be sought in the elements responsible for control the level (pressure switch, pcb...etc.) or control draining water (drain pump, pcb, filter....etc.).
The precondition that the machine goes into a spin cycle is that pressure switch folded down to position "empty of water".
Dado
Jul 24, 2015 | Frigidaire ATF6000ES Front Load Washer
I have a Samsung front load washing machine wf328aaw/xaa. the drain pump motor is not getting the 120 to run the motor. I tested the resistance on the motor and it tested ok as 13.8. when I put the w
Have you resistance tested the cable from the pub to the pump connections ? The sensor problem I had which was linked to failure to drain was connected to a piece of tube some sort of pressure sensor .. The tube had a split so it was not detecting the pressure (of I assume height of water left in the machine) split was at the top .. Bit of trimming of the pipe fixed the problem
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
I just got my pump replaced and now i need to reset my samsung washer it still shows nd and stops
The problem is probably in the control panel or water level switch. I just posted a procedure to clean the relay contacts for the pump motor relay. This little relay is on the control circuit board and is not normally customer accessible. But the alternative is purchasing a new control circuit board (which in my case was not available) or replacing the washer. Please refer to my solution for the problem "Drain Pump doesn't work" posted today.
Oct 18, 2014 | Samsung WF206ANS Front Load Washer
Samsung WF210 not draining
Unplug the washer and check for all kind of clogs in drain hose and check for clog in hose from tub to pump and remove the pump and check for dirt and junk inside pump clean the pump with warm water and test pump for continuity as the pump running properly other wise replace it with the new one and reinstall it ,it should solve problem
Jul 10, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung wf 210 front load washer nd code
Check out the drain hose and connection hose to pump and then check out the pump in the washer for any clog or junk stock in the pump and clean it with warm water and test it is working properly or replace if it is not and reinstall the pump
May 21, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
Error code 26
You have a clog some where
F26
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Front Load Washer Repair Not Draining or Spinning How to Unclog the Drain...
May 31, 2012 | Maytag Washing Machines
Samsung WF337AA Front load. How does it know it has not drained? Is there a sensor? Ours is working intermittently. It is draining but not spinning all the time. Sometimes we get a ND even though I can...
Make sure there is no foriegn objects in the tubes or drain pump. You might want to replace the drain pump and If it still has a problem, the main pcb. First check for loose wires around the main board and drain pump.
Nov 28, 2009 | Samsung WF337AA Front Load Washer
Error code 10E and 01E
Code 01E: Water level becomes too high;
Code 10E: The drain is clogged, or the drain pump is blocked/defect.
Possible solutions:
- Check if the drain is blocked with something, and clean it;
- Check if the drain pump works, replace it (if necessary);
- Replace the Water Level Control unit.
Feb 22, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
