Question about Hardware & Accessories
Operate a work choice outdoor mechanical timer
Don't understand the instuction. thought it would run 6 to 10 pm on all night long
  • 5,245 Answers
  • 183 Answers
SOURCE: on the malibu timer for outdoor lighting does not work
be sure that you have the AM/PM set properly. They are quite simple to use but this one can get you.
Posted on Feb 08, 2010
  • 5245 Answers
SOURCE: i have an intermatic indoor outdoor timer the
Open following link for Intermatic timer troubleshoot
http://waterheatertimer.org/Troubleshoot-Intermatic-timer.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 30, 2012
SOURCE: How do you use a
Brinks 42-1020 is analog timer with 48 segments (pins) located around edge of dial.
Each segment (pin) represents 15 minutes in 24 hour day.
Segments on this timer push down and outward.
Open following links for instruction illustrations:
http://waterheatertimer.org/pdf/Brinks-42-1020-manual.pdf
http://waterheatertimer.org/How-to-set-timers.html
Posted on Aug 19, 2011
SOURCE: Woods Model 59200V Indoor Mechanical Timer. Not working
book says peg should be down for on and peg should be up for stop. How the hell does one pull the peg up...it is blocked and can only be pushed down...now what I am missing?
Posted on Dec 19, 2009
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
Sep 17, 2014 | Hardware & Accessories
Noma 052-8870-6
OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
Dec 02, 2013 | Hardware & Accessories
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Dec 17, 2010 | Woods Outdoor Lighting Timer
My grow light is on a timer and was off last night when it was suppose to be on i played around with it and got it on, but once again as soon as it went off wont go back on... Maybe it is something to do...
check and make sure you have the timer right am/pm.also the mechanism that rotates the timer might also be bad or going bad.if the am/pm timing is set right i would try another one from your local home center and if it works its likely the timing mechanism.
Mar 24, 2010 | Garden
On the malibu timer for outdoor lighting does not work
Feb 08, 2010 | Intermatic Malibu 300W Power Pack...
Dec 18, 2009 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Lost instuctions to program Model N1560 Noma outdoor timer
Dec 01, 2008 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hardware & Accessories Logo
1,060 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
