How does EDUP High Definition TV wireless card EP-MS8512 work (configuration/installation) I have a flat screen tv sharp aquos LC-52LE810UN with rj 45 port how can i go online?
THEY DON'T EMAIL ME THE MANUAL I EXPLORE THE CD IS NOT THERE
tom19511
  • 1601 Answers
SOURCE: EP-8K3A EP-8K3A motherboard Video trouble
Did you enable the add-on card in the BIOS.
Posted on Jan 14, 2008
mattballew
  • 89 Answers
SOURCE: Line in port not woorking
i cant say that i have ever made my Line in port work... try the microphone in port. maybe that will work.
Posted on Nov 25, 2008
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
anandg27
  • 1272 Answers
SOURCE: i cant access the internet.
Check if you are able to ping a website say yahoo.com from the concerned computer.
you may even have to disable firewalls on the computer or assign static IP address.
Posted on Jun 22, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have a Sharp Aquos 52" LC-52LE810UN. I turned the tv on and assuming that my cablevision box is working, what do I do in settings or other aspect of the tv to make the 1080i work. I have another box...
Actually the cablevision box determines the 1080i. Once it is set on that box the television simply displays it. The cablevision box will have to be connected to the television with component cables or one hdmi cable in order for you to be able to choose 1080i on it. Usually there are resolution numbers on the side of the cable box that tell you if it's on 480, 720, or 1080. There is a red light next to the one the cable box is displaying. If this is not the right kind of cable box for that then you will need to get another one from Cablevision or just eliminate the box entirely and run the cable straight to the television. Yes you can do that and use the television's digital tuner for a beautiful, crisp picture. After removing the cable box and screwing the coax cable onto the back of the television you will have to press the input button and scroll up to TV and press enter (use a Sharp remote). Then press menu and scoll over to setup and down to CH setup. Then scroll to CH search and begin searching for the available channels. You will now use a Sharp remote to change channels.
Jul 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I need a manual for my sharp aquos led lcd hdtv LC52LE810un
I'm glad to provide the manual for the TV. Please click hear and enter your email and code mentioned on the page to download the manual.
Please let me know if you require any additional help.
Jun 16, 2011 | Sharp Televison & Video
How do I hook the Sharp LC-52sb55u up to the internet? To get Netflix mainly. Also, is it possible to stream tv directly to the tv, in place of cable
Your HDTV would have to have internet connectivity, either an RJ-45 ethernet jack on the rear panel or wi-fi capability. Sharp calls it the AQUOS NET feature on the TV and is usually an ethernet port. If your TV does not have this capability, you can use a laptop and hook this up to your HDTV. You still need high-speed internet service and a Netflix account.
Mar 13, 2011 | Sharp LC52SB55U LCD TV
I get a large black rectangle covering 1/3 of my
I have a similar problem using an older 20" flat screen standard definition TV. (not High Def). I can see a little of the picture but more than 2/3 is covered by the black. My model is LC-20SH7U.
I used sharpusa.com "contact us" section.
Hopefully I get some kind of reply to report what they say.
May 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The audio on my LC-45GD6U goes in and out (mostly
if its fine on other channels i would not suspect the tv
Aug 26, 2009 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Picture not clear
Get a HDMI lead it makes HD tv look how it is suppose to look HIGH DEFINITION. You'd think it naturally is suppose to look great but these people are rip offs you need that additional peice which should make it spot on for you. Try stores such as maplin & currys. Get the gold plated HDMI lead better quality
Good luck
Apr 27, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
