Question about Aiwa Audio Players & Recorders
How do i change a stylus on aiwa PXE88
How do i remove my old stlus and replace it with a new one on model PXE88
    Champion:
  • Aiwa Expert
  • 271 Answers
Hi, Grip the stylus between your thumb and forefinger. Pull the stylus down toward the front. As it comes loose replace the downward motion with a forward one. When fitting new stylus insert the tongue of the stylus into the groove in cartridge. Push it backward into place and then upward. John. Stylus City.
Posted on Nov 29, 2014
Reconnect the belt on an AIWA PX-E860 turntable
To replace a turntable drive belt.
Before starting any work on your turntable disconnect it from the mains power supply. Remove the stylus or complete headshell to prevent any accidental stylus damage.
1. Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes either side of the centre spindle and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flat without any twists.
5. Flip platter over to the right way up. A correct fitting belt will stay put and an over sized belt will fall off.
6. You will see 1 or 2 large rectangle or square shaped cut outs in the platter near to the outer edge. Through one pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
You have now successfully completed the process.
MUSIC IS LIFE, LIVE IT LOUD.
Copyright.. Styluscity, John Harrison.
Dec 16, 2014 | Aiwa PX-E860 Turntable
How to replace stylus on AIWA stereo turtable
the old stylus snaps off. pull evenly straight out. The new one snaps on in its place. Do not touch the needle as it is easily damaged.
Jul 02, 2014 | Aiwa PX-E860 Turntable
What can I use to replacemy stlus/needle?
You'll need to do an internet search for a compatible Stylus that was made for your record player. It has to match exactly. It doesn't necessarily have to be made by the same maker though, just compatible.
A search using the words "Pioneer replacement stylus" gets you: http://www.needledoctor.com/Contact/Pioneer_2 and many, many more. Try "Sanyo replacement stylus" and you get http://www.styli.co.nz/sanyo.html.
There's lots of them out there for every manufacturer/model.
Better yet, try to look up your stylus part number in your owners manual, if you still have the old one look for a part number on it. Then look it up on EBay or Amazon. It's a lot easier to track one down if you can find the part number of the original part. Since you didn't list what model record player you have you'll just have to start with the manufactures name and start from there. Lots of companies are still out there that sell them. Good luck.
If you need more help let me know. I'll be glad to try and find one for you. I'll need the manufacturer of the record player and the model number.
May 11, 2014 | Audio Players & Recorders
How do I remove the stylus of an Aiwa PX-E850 Turntable?
Hi, grip the stylus between thumb and forefinger. Then in a pulling down and forward motion remove stylus. Cheers john. Stylus City
Apr 02, 2014 | Aiwa PX-E860 Turntable
As the stylus touches the record the turntable stops rotating
If this is a belt drive turntable you need to replace the belt. Make a note of how it fits, before removing the old one.
Sep 25, 2010 | Aiwa PX-E860 Turntable
Where do I get drive belts for a aiwa xr-m10 cassette player
Try eBay, i've been looking for these on the internet, they sell kits (long and short variety), containing several pairs of different measures (about $7 per kit), and are supposed to fit various brands and models (including aiwa).
...a hint: a belt measure tells you the diameter of the circle formed by that belt
...another hint: old belts are loose, which means they are a bit longer than the new ones, so when you select the new belt from the kit, it should be a bit shorter than the one you removed from the deck (old belt - bigger circle, new belt - smaller circle).
I'm aware that not all aiwa models are the same, the one i was repairing a while ago had a double tape deck, each deck containing two belts, one long and one short, they were a bit tricky to change, but i didn't need to disassemble any of the mechanisms, i just had to remove both decks from the housing for easier access to the belts which required prior removal of the top cover and rear panel. After that it was some 4 to 6 screws and 4 connectors (just about half less in your case, i believe).
I can't tell what your unit looks like on the inside, but in my opinion aiwas are relatively easy to take apart, but then again, i could be wrong...
Hope this helps you get closer to a solution.
regards
3rq8 (Triarcuate)
Jul 08, 2009 | Aiwa XR-M10 Shelf System
Epson STYLUS DX4400
Have you removed the pull off tape from the top of the cartridges, it lets air in enabling the ink to flow, easy mistake!
May 27, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson STYLUS DX4400
Dump then program. Start your pc again wtih printer plugged in. Let it install program automatically.
Feb 21, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Turntable with no stylus
Provided the replacement stylus is the correct one for the cartridge you have, it should just slide in from the front of the tone arm into the cartridge.
Jan 18, 2009 | Aiwa PX-E860 Turntable
Paper Jam in Epson Stlus CX4800
well..you may want to look inside, to see if there's any varmints in the paper path, eh?
May 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
231 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
