Question about Electric Health & Beauty
I have an arrow electric bike that wont take a charge green lite comes on but thats it
I just purchased the bike from local kid who didn't take care of it I have the charger and when I plug it in to batteries to charge the green lite comes on saying its fully charged but its not batteries are six months old
  • 3,904 Answers
Either the wiring to the battery is not correct or the batteries need to be replaced.
Posted on Nov 30, 2014
  • 103 Answers
SOURCE: My Jazzy wheelchair will not charge or run
First have the batteries tested to be sure that they are good. Just because they are "new" doesn't mean they are good. Then with the batteries disconnected plug the charger in and turn the chair on. This will tell you if the charger is good.
If both of these are good then you have an electrical problem. You need to call a local tech.
Posted on Mar 09, 2009
  • 205 Answers
SOURCE: My hoveround MPV5 will not operate. fully charged
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 15, 2009
  • 37 Answers
SOURCE: Jet 3 Ultra won't charge
You can find the Fuse behind the foot rest. Take the pin located under the foot rest, and the casing will come off exposing the fuse.
Posted on Jun 24, 2009
  • 103 Answers
SOURCE: Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
Posted on Nov 10, 2009
  • 175 Answers
SOURCE: Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
Posted on May 23, 2010
Cant open jt27 staple gun to load staples
Hi Maria, I'm sorry you are not having luck with your JT27 stapler. Unfortunately you did not purchase the correct staples for this tool. The JT27 Stapler uses the JT21 staples in a green box. The staples come in 3 different sizes (1/4", 5/16", 3/8"). You can purchase these staples online or at your local Home Depot or Lowe's Store.
As for opening the tool - please see the attached picture for assistance.
May 07, 2015 | Arrow Tools & Hardware - Others
Cant get batteries to charge
hi, you could have blown the fuse contained with the battery unit ?
If you have a electrical meter put the probes into the two outside holes of the charger socket, do not let them touch and check the DC here. No voltage shown then take the battery unit apart to locate the fuse. and check the leads have not come off the batteries.
Take care with dis assembly.
Regards
Dec 30, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My back tire isn't spinning
WOW!!!WHAT A JOKE!MY KID SAVED $470 AND PURCHASED HIS MX 650 ONLY TO HAVE THE REAR FREEWHEEL BREAK THE FIRST WEEK RIDING IT.NND BY SEEING ALOT OF THE SAME PROBLEMWITH EVERYONE ELSE.RAZOR SHOULD' VE AT LEAST PUT A HEAVYDUTY ONE IN IT.OK PEOPLE LETS FIGURE IT OUT IF ANY ONE KNOWS AGOOD BEARING COMPANY,POST IT.MY KIDS BUMMED HE CANT RIDE IT
Dec 26, 2010 | Razor MX650 Electric DirtBike
2008 R6. Battery discharges completely when allowed to sit. Owner replace four batteries. Voltage checked with bike at 5000 RPM and is charging (14.4 V). When the bike is put on a Battery Tender, the...
You have a voltage drain on your bike while the key is off that is why the tender wont full charge the battery. If you have any electrical accessories such as an alarm try disconnecting them they may be draining your battery while sitting. If no accessories then you have a short somewhere in the harness causing the drain.
Nov 02, 2010 | 2008 Yamaha YZF-R6
Ds lite wont power on the green light is on, any suggestions of a diy repair
The wireless board on the main motherboard must be checked to see if it has come loose. This presents as the charge orabge lamp works with the charger pluged in, On green light comes on when power switch pushed once and stays on without flashing. Pushing the power switch once more puts the green light out. Bruce
May 08, 2010 | Nintendo DS Lite Console
Ds lite battery wont charge i have charged it overnight but nothing the green light goes on but that is it
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Aug 26, 2009 | Nintendo DS Lite Console
2007 JackPot not charging
Check the connections on your battery terminals. They could be loose and/or gummed up.
Discounect the battery and clean up both the wires and terminals on the battery using a wire brush and electrical parts cleaner.
IMPORTANT!- do NOT ground the battery out by cleaning both terminals at the same time. LOTs of sparks and fire hazard. Plus that whole shocking yourself isn't fun either. Been there.
If that doesn't fix your problem, then more than likely you have a short coming off of your charging unit in the primary, or a bad ground.(Left side cover) Its a new bike, so there's a very small chance that its the charging unit itself.
Hope this helps
Good Luck!
Skuban
Jun 24, 2009 | 2007 Victory Vegas Jackpot
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Health & Beauty Logo
54 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
