Question about Samsung ML-1860/SEE ML-1860 Mono Laser Printer 8MB 1200 x 1200dpi
Printer sensor failure #3 3112 samsung ML1860
    Master:
  • Samsung Master
  • 551 Answers
Dear its related to the fuser assy. check the thermostat for open replace it,check the thermister for open.replace it. Thane Main PBA. In general this type of model if problem repeated replace the Main PBA or update firmware with latest. Thanks.
Posted on Dec 29, 2014
Error code 15e samsung refrigerator sise by side bottom frezer
existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Feb 05, 2017 | Samsung Refrigerators
Samsung ml1860 service manual
The repair manual is not published to the internet, sorry.
Nov 22, 2016 | Cars & Trucks
Sensor Failure:#A3-3112.
This is an indication that the feed sensor is broken or just being block by an ink blotch or a small paper. If you are comfortable in opening your samsung printer, please check the sensors behind the paper feed rollers. Wipe them clean with a cloth with isopropyl alcohol and make sure it is clean.
Put the parts back together. Do not turn on the Printer yet. Press and hold the power button for 30 seconds (while it is plugged off the main power) and release it. Plug back the power and test your printer. Check if this will remove the error message. If not, consider yourself buying a new printer as this is not a replaceable part.
Hope this helps.
Jul 24, 2016 | Office Equipment & Supplies
I GET A "DRUM ERROR" MESSAGE... I'VE DON EVERYTHING... KEEPS SAYING... "DRUM ERROR." ALMOST NEW UNIT. WHAT?
Description HUM sensor failure Causes 1 Harness connection failure of THM/HUM sensor. 2 THM/HUM sensor failure. 3 Engine PCB failure.
Jan 02, 2015 | Brother MFC-9840CDW Laser Printer
Why sensor failure:#3-3112
Dear
Its related to the fusser assy.. Pl. check the thermistor(it may open) its harness (continuity)and main PBA.
Thanks.
Sep 03, 2014 | Samsung ML-1860 Mono Laser Printer 8MB...
Dear
Pl. check the fusser assy. thermistor resistance if it open replace it,check thermostat and heating lamp for short, if open replace it. If all are ok, try to up date latest firmware. if not solved replace the main board.
Thanks.
Jul 13, 2011 | Samsung ML-2855ND Laser Printer
New printer samsung CLP-310 - "sensor failure ambient temperature" after Power On
Check the cable in the door. There is a cable that goes to the sensor in the door, it will come loose when the door is accidentally bumped loose and pulls the cable out of the socket. There are the two hinges on the ends, two guide posts, and a flat cover, the cable is under the cover.
May 06, 2011 | Samsung CLP-315W Laser Color Printer
Printer Problems...red status light glowing
Chances are that you have the same problem as found here. I am guessing that the toner waste container needs to be emptied (you can do it your self) and/or the sensor is acting up.
http://www.fixyourownprinter.com/forums/laser/34677
May 25, 2009 | Samsung CLP 300 Laser Printer
When the red light is on, what does that mean? It not printing!
check if their is still paper in the printer cassette or check if their is paper jam
May 23, 2009 | Samsung CLP 300 Laser Printer
Samsung ML-1860/SEE ML-1860 Mono Laser Printer 8MB 1200 x 1200dpi Logo
139 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
