Question about Dryers
How do I get the top off my White Knight CL447WV Tumble Drier?
How do I get the top off my White Knight CL447WV Tumble Drier? I thought you just had to remove the four screws at the top back, and it would slide back and off. I seems that it might be somehow fixed to the plastic moulding on the top front, and I'm scared to pull hard in case I break something.
  • 1,249 Answers
In reality, most of these aged appliances take quite some amount of force to get apart after they have been together for years. The model you listed is accessed from the top after the lid is removed for many repairs.
Posted on Dec 09, 2014
Testimonial: "It's only a couple of years old; there's a squeak, and I wanted to sort it out. I've tried getting tough with it, but no joy."
  • jeff5may32 Dec 09, 2014
    If you go to a local parts house, they will be more than likely helpful with your particular model. If you ask about a roller or bearing availability, they have exploded diagrams and repair instructions they may give you freely as part of their service commitment with the manufacturer. In this regard, some shops are more giving than others, and it doesn't hurt to shop around. The more helpful dealers tend to stay in business longer, developing a loyal customer base due to their service.
Oceti
  • 51 Answers
SOURCE: white knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Posted on Dec 08, 2007
  • 1462 Answers
SOURCE: WHITE kNIGHT tUMBLE DRIER THAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Posted on Sep 05, 2008
apart4u
  • 213 Answers
SOURCE: Tumble Drier does not heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Posted on May 10, 2010
SOURCE: white knight tumble dryer (condensing)
I have a whikpool condenser dryer that seems to work but has all the lights come on and a buzzing noise,any ideas to what it could be please? I have clearned all the filters etc
Posted on Dec 02, 2010
  • 18 Answers
SOURCE: How do you remove top from a Hotpoint CTD80 tumble
2 screws at the back and then push the top towards the back of the machine...you might need to give it a bit of a wack, if it's too tight just take the 3 screws from the back of the side panels and things will loosen up a little
Posted on Jun 20, 2011
I can get the back of my white knight 38AW tumble dryer
try lifting the top of the dryer it usually pops up in the front then you will see the drum and the belt
Sep 27, 2012 | Abbaka White Knight 38AW Electric Dryer
How do you remove top from a Hotpoint CTD80 tumble drier. 2 Screws holding at back. Does it slide forward or back or lift vertically, or are there other screws to remove?
Dec 10, 2010 | Hotpoint TDL15 Electric Dryer
HOW DO I CHANGE THE BELT ON A WHITE KNIGHT CL447WV - DO I REMOVE ALL OF THE SCREWS ON THE BACK + IS THERE AN EASY WAY TO GET THE BELT ON?
You must pop off the top of the dryer then remove the front after the front is off you can get to the drum. The belt goes around the drum and the motor pulley and under the tensor wheel after you get belt on replace front and top since you do have the back apart you can do it this way:
Remove the back -lots of screws- to allow access the drum. Then tip the machine on its face and unscrew the access panel that lets you get to the drive wheel. After feeding the belt around the drum from the top, reach into the access panel and pulled the belt over the pulley wheel
Which is easiest, the choice is yours as they are about the same either way. Hope this helped Tim
Nov 27, 2010 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
Feb 12, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
Nov 01, 2008 | Dryers
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
Sep 05, 2008 | Dryers
White knight 767 tumble drier
Good luck.
Dec 08, 2007 | Dryers
Dryers Logo
59 people viewed this question
Top Dryers Experts
