Question about Hard Computers & Internet
What is A/V rated hard drives. Any one can give right suggestion.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Hard Master
  • 884 Answers
Hi
A/V rated hard drives are specifically produced for use in such things as Digital TV recorders, Xboxes, and other equipment requiring the storage of video or audio content. They usually also work with computers as internal or external when suitably connected.
Cheers
Posted on Nov 29, 2014
  • pava kumar Dec 03, 2014
    Is there any good companies to provide A\V HDD.
Bad Hard Drive - Toshiba Satellite A665-S5170
I suggest you back up your hard drive right away and have the hardware tested for possible replacement.
Sep 18, 2012 | Toshiba MK6465GSX) 640 GB SATA II Hard...
My pen drive is write protected. I want to format it . plz suggest me
try to check disk your pen drive.
Steps:
1.)Right click your usb and go to PROPERTIES
2.)Go to TOOLS tab
3.)on Error checking click CHECK NOW
4.)Click the two CHECKBOX and wait for it top finish.
5.)you can now try to format your pen drive.
Rate me if i helped.
Sep 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Will not boot up
Even when it is being charged? And is the actual computer not turning on or is it turning on and the screen is showing no picture. two different problems.
Jun 30, 2011 | ASUS Eee 4G Notebook
Show a step by step procedure to how to reformat a hard disc
- if the hard disk is inside the system use your operating system disk
- boot to the disk by pressing F12
- if you see "press any key to boot to disk" hit the spacebar right away
- if your usinf windows XP delete or partion by highlighting the partition and hit "d" to delete
- it will ask you confirmation, hit "L"
- your system will ask you to reformat hard drive
- for win 7 same process
- first delete partition
- click drive advance option to see the delete option
- delete all partition
- click reformat
hope I answer your question step by step
Jun 07, 2011 | Computers & Internet
My external HDD is no longer recognised by my PC. The usb port I tried works with other devices so that's not the reason. The curious thing is that when I connect the HDD to my TV I can view & play...
Plug it in, then on your desktop right click the My Computer icon, then click on Manage. From the window that opens click on Disk Management. In the right hand pane, you may then see your drive displayed. Right click in the lower right pane on your device and click on Explore. If it open the drive to show the files, you should be able to come out of all the windows and then access the drive normally.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | Western Digital My Book Essential 1TB...
My computer does not recognize my external hard drive when I connect the usb
HI rvcruz. I've solved a few problems like this. Connect your hard drive. do you hear the "tutin" sound when you connect USB devices? If you don't, that means you have a problem with your hard drive. Either the case is bad so you just remove the hard drive from the casing and put in on another one (it could be any extrenal case for hard drives.. as long it has the same interface - SATA or IDE). If you do hear the "tutin"sound, go to Start - right click on MY computer and click on "Manage". Then go to "Disk Administration" above "services and applications" and verify if you see your hard drive. Probably you have to initialize the disk or Assign a letter by right clicking on it. But first try removing the hard drive and connect it to another computer WITHOUT the case to make sure it's not the hard drive. I hope this helps and don't forget to rate and give positive feedback for our free support today. Thank you :D
Apr 29, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
MAxtor Basics 160 GB external hard drive does not connect
Check the USB ports make sure there giveing the right power also do not use a USB hub on this drive. Do not plug it into printers with usb or anything else but the computer make sure you are also checking how many devices you have on the usb ports. If all else fails and it dont work you say its new I would take it back to the store where I bought it, If you find this information useful please use the Fixya s a rateing thank you.
Apr 24, 2009 | Maxtor Hard Drive
N-91 Problems
Menu>Tools>Hard drive>Options>Tools>Format hard drive
Formatting the hard drive will clear any data stored on it. This should be a last resort and we'd suggest trying to scan the hard drive first. This will attempt to fix any hard drive disk errors. If your N91 does not have the scan option (some don’t) then connect to your PC in mass storage mode, right click on the F: drive, then hit scan.
Apr 29, 2008 | Nokia N91 Cellular Phone
Exturnal hard drive fell
The fall was probably too much for it. If it was powered up at the time of the fall and the fall caused a substantial shock, it is most likely gone. A running hard drive cannot take much shock.
Before giving up on it, if it was mine, I would remove the hard drive from the portable case and plug it directly into a computer either through a USB adapter, directly to a motherboard or any other available method you may have.
The purpose of that is to bypass the case's electronics and deal directly with the actual hard drive.
If it wont read from it by doing that, you are done.
You could try a warranty claim if it's new enough.
If your data is extremely important, you can send it to a data recovery service but the costs are high. $500 or $1,000 for data recovery isnt that unusual.
Re-post here, let me know how it goes.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Oct 18, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maximizing life of external HD
keeping hard drives running will cost more on electric and heat generated from drives as I've found out on of my 160gig sata drives burnt out because I was using pc 24hrs aday and night if I had put a cooler on the bottom it would have lasted 5 years but I only lasted 8 months you can give your hard drives 2 twice or even 5 times life span if kept at room temperature listen to you own advice it's your data and hard drives do what you wish I'm only her for advive you can tak itor leave it
Oct 01, 2006 | LaCie Design by F. A. Porsche 160 GB Hard...
Computers & Internet Logo
42 people viewed this question
Top Hard Computers & Internet Experts
Nyte_Ryder
David Clark
David Clark
john smith
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
